Eyedoc Ed
How do I fix an error in Bridge stating problem with Dynamic Link Media Service?
Dec 8, 2012 10:59 AM
I recently installed CS6.  I get the message "dynamiclinkmediaserver has encountered an error">    [..\\..\\Src\DirectoryRegistry.cpp-283]
I am using Win 7 Home 64 bit
I have gone to the Adopbe site and downloaded a
"patch" for the Dynamic Media Link Server and installed it.  This does not help.
Thanks for your assistance.
  • Sudarshan Thiagarajan
    Oct 15, 2010
    Dec 9, 2012 5:23 AM   in reply to Eyedoc Ed
    Ed,
    Is this when you open 'Bridge' itself or 'Mini-Bridge' from Photoshop?
    Either way, can you right click the application .exe and 'Run as Administrator' to see if it helps?
    -ST
    Oct 15, 2010
    Dec 9, 2012 12:44 PM   in reply to Eyedoc Ed
    How big is the .mov file you're trying to import? Can you try importing a smaller/ different file?
    -ST
    Oct 15, 2010
    Dec 9, 2012 1:06 PM   in reply to Eyedoc Ed
    Did you update your video card driver recently after which this issue started occuring?
    Also, do you have a firewall or a network proxy program that controls ports in your OS?
    There have been some known issues with these two reasons earlier.
    Oct 15, 2010
    Dec 10, 2012 5:07 AM   in reply to Eyedoc Ed
    That wont help. The application does know where the file is located, but is encountering trouble while accessing it.
    Two things I can suggest at the moment:
    • Clear Bridge Preferences (unsure if this will help but no harm trying it) - Hold down Ctrl + Alt while starting Bridge, dont leave it till you see a pop-up dialog box. Choose to 'Reset' preferences and start up Bridge to see if it works fine
    • Try using CS Cleaner tool to clean all traces of previous installations of Creative Suite apps and re-install afresh - http://www.adobe.com/support/contact/cscleanertool.html
    Like I said, this is only experimental. Let us know if they help. If not, I'll see if I can escalate this issue to someone at the Engineering team within Adobe. (I'm a normal user, just like you!)
    -ST
