For some years now I have used Shift/Command/I to italicize selected text. Today ID has decided this no longer works. Now when I use it, the open panels are moved from the right side of the window to the left side. Very strange. I have made no changes in key commands so it did this on its own. I did search to see if I could find a function for moving panels, to see if this key combo was somehow assigned to it but could not find such a function. Anyone have any idea what has happened here?
You cannot assign the single keyboard shortcut to 2 functions in Indesign at same context so you can check to what function this keyborad shortcut is applied to aind to which context.
Remove if you find this keyborad shortcut applied anywhere else,
else, Replace your preferences.
Yes, I know. My posting was apparently not clear. First, I have not assigned any new keyboard shortcuts for several months, so it is not from a new assignment. Second, I cannot find this shortcut listed when I searched through all the keyboard commands that I have in my custom layout. This is why I am puzzled. I have not made any change yet this has happened and I cannot find out why.
Can you check these, under "Product area: Views, Navigation"?
Open/Close all panels in side tabs --- Default: Opt+Cmd+Tab
Open/Close panels in left side tabs --- [none defined]
Open/Close panels in right side tabs --- [none defined]
(Although I doubt it's actually one of these that suddenly gained a hotkey. I can't think of a function that moves your panels from left to right.)
Coincidentally (or not), did you know that Ctrl+I (Cmd+I in Mac parlance) historically inserted a Tab character in the absence of a real Tab key? And the Tab key is used for manipulating panels. Did you recently install some sort of keyboard helper software, or some other background software that acts on a system global hotkey? IIRC, these have been known to mess up ID's own key handling.
Thanks for the guidance. I did read about resetting prefs and did so manually. On reopening ID, the same issue existed, however I figured it out and traced it to a third party program called Moom which sets windows into a particular position. I had put in a keyboard shortcut into that program that would put the ID window where I wanted it and it was intercepting the same commands used for text italic. Strangely, it was affecting the palette and not the window that I had specified for its action. Quitting Moom solved the problem and all is again right with the world.
Richard
North America
Asia Pacific
