unicode arrows in FM 10
Dec 9, 2012 11:57 PM
Tags: #unicode #character_palette
OK, so I'm using Arial as my standard font. I go to the curiously geeky character palette and select Arial as the font. Then I locate 21E7, a.k.a. upwards white arrow; it's clearly visible on the palette, which is encouraging. But what shows up in my document, both on-screen and as a .pdf? a question-mark.  Clearly some sort of gap or discrepancy between interface and reality which I'm failing to appreciate … hints and tips welcome.
    Dec 10, 2012 4:08 AM   in reply to Niels Grundtvig Nielsen
    > ... so I'm using Arial as my standard font.
    Try Arial Unicode MS.
    Dec 10, 2012 5:59 AM   in reply to Niels Grundtvig Nielsen
    Are you using the system or the FM character map?
    Anyway, I just tried this in FM9 on Win7/64.
    The 21E7 code point is not populated in "Arial", although simple Arial does seem to have numerous Unicode glpyhs. I had expected it to be the same old Western 1252 set, but MS has apparently extended it somewhat.
    21E7 is populated in "Arial Unicode MS", and pastes into FM with no problem, as an "UPWARDS WHITE ARROW". If I change the font to Arial, it reverts to a "?".
    If I were going to use this in a document, I'd be tempted to implement it as a Variable, so that the font assignment is deliberate, sticky and ends after the glyph.
    Character Format:
    Font Family Arial Unicode MS (everything else As-Is)
    New Variable:
    Def: <Arial_Unicode_MS>\u21e7
    Dec 10, 2012 6:35 AM   in reply to Niels Grundtvig Nielsen
    When I run this experiment in Wordpad, I get a similar result; a "no glyph" box when Arial is applied to the U+21E7 character.
    If I save that setup as RTF, and open it in MS Word, on the other hand, Word silently converts the missing glyph's font to "Cambria Math", and shows an outlined up arrow. This is all-to-typical "Bill Gates is smarter than you are" MS behavior. I haven't checked to see if one can drill down into a menu that would turn this feature off.
    Dec 11, 2012 4:01 AM   in reply to Niels Grundtvig Nielsen
    > When the FM character palette ...
    Ah. I was using the MS Windows7 Character Map, and it does not show U+21E7 as populated in regular Arial.
    Dec 11, 2012 4:34 AM   in reply to Niels Grundtvig Nielsen
    Hi Niels
    Try this:
    1. Search for "Upwards arrow" on this site:
    http://www.fileformat.info/info/unicode/char/2191/index.htm
    Typing Alt +2191 does not work, so proceed with the next steps.
    2. In Windows Character Map, go to Unicode 2191.
    3. Copy the character and paste it in FrameMaker.
    This always works for me, even in DITA XML and HTML.
    Cheers
    Yves
    Dec 11, 2012 4:58 AM   in reply to Yves Barbion
    > Typing Alt +2191 does not work ...
    There's a registry hack to enable that, and other alternatives.
    Here's a typical resource:
    http://www.johndcook.com/blog/2008/08/17/three-ways-to-enter-unicode-c haracters-in-windows/
