Dreamweaver 6 freeze
Dec 10, 2012 9:06 AM
Dreamweaver freezes up whenever I mess with the pallet tab groups.  Now I have moved some around and as soon as I succeeded I quit dreamweaver so my workspace will be saved before another freeze.  I also froze merely by clicking on the actions tab when the snippets tab was on top.
I are running version 10.6.8 mac on a mac pro
    Dec 10, 2012 9:09 AM   in reply to Daryl Hunter
    Moved from the Creative Cloud to the Dreamweaver forum. They will be able to help you here.
    Dec 10, 2012 1:56 PM   in reply to Daryl Hunter
    Sorry to hear, Daryl.
    Does this freezing happen even if you have no documents open in Dreamweaver?
    Has it always happened since you install Dreamweaver CS6, or did the freezing start later on?
    Do you have any extensions installed for Dreamweaver?
    If you're not sure, you can check by going to Help > Manage Extensions.
    If you do have any installed, which ones?
    You might try disabling some or all of them, then restart Dreamweaver to see if that helps.
    Dec 10, 2012 2:34 PM   in reply to Daryl Hunter
    Definitely odd. Since you just installed it, there would be no loss in manually resetting the preferences for the application.
    See this article for instructions: http://helpx.adobe.com/dreamweaver/kb/restore-preferences-dreamweaver- cs4-cs5.html
    After doing so, start up Dreamweaver and see if the problem persists.
    Also, when was the last time you restarted your Mac?
    Dec 10, 2012 3:26 PM   in reply to Daryl Hunter
    Does this happen with and without the Application Frame enabled?
    It's enabled by default. To disable it, go to the Window menu and click to uncheck Application Frame.
    When Dreamweaver freezes, what do you do in order to get it back up and running?
    e.g. Force Quit
    Do you see any error messages at all?
    I'm wondering if the Console log might tell us what's going on. To test this out:
    - Open Dreamweaver, but do not yet move any panels around.
    - Go to /Applications/Utilities and open the Console application.
    - On the left of Console, select 'All Messages'.
    - Click the Clear Display button to clear off what's there.
    - Try to move around some panels in Dreamweaver. Do so until the freeze occurs like before.
    - Go back to Console, select everything in the log (CMD+A or Edit > Select All) and then copy it (CMD+C or Edit > Copy). Paste what you copied into your reply.
