Just started creating Blu Ray DVDs from MXF OP1a AVC-I 100 Master files.
I use AME to convert to BR matching the settings of the master. It converts successfully creating video .m4v and PCM files.
When I import them into Encore 6.02, the Project window info displays the video file as " Remix. m4v Video file Untranscoded". And " Remix.wav WAV audio "Untranscoded"
Whats up with that? If they have been trancoded by AME why does Encore say they are Untranscoded?
The project panel shows both the DVD and the Bluray transcode status/settings. Make sure you are looking at the Bluray column.
What is the audio format for your disk settings? If set to dolby, Encore will show your pcm as untranscoded. Also, try changing the setting for the pcm asset to "do not transcode."
Are you using 5.1?
Are the settings of the master BD compliant?
Thats was a response at lightspeed. Thanks Stan. You hit both nails on the head.
Yes, I didnt scroll far enought to the right to see the BR columns. And yes again, project audio setting were set to dolby.
Checked under Project settings and everything seems right. Not sure I know what you mean by "Are the settings of the master BD compliant?"
For example, the presets include H.264 and H.264 Bluray. When you use the settings from your source, you can end up with a file that is not bluray compliant. If it is not compliant, Encore will not let you set it to "do not transcode."
North America
Asia Pacific
