Equal distance between text on a path
Dec 10, 2012 9:19 AM
I have a circular path where I've got 5 words of text that I need to have equal distance between each word.
What I've done is create 5 text paths overlaying each other so I can move the text around the path but is there any quick way to creat equal gaps?
    Dec 10, 2012 9:44 AM   in reply to greencode75
    Are all the words a similar length? And what do you mean by "equal" gaps?
    These are spaced at equal degrees (72°) around the center but the space between is slightly different due to the difference in character count.Screen shot 2012-12-10 at 9.42.29 AM.png
    Dec 10, 2012 9:39 AM   in reply to greencode75
    use 1 text path, and Justify All Lines, see sample here
    http://forums.adobe.com/message/4774068
    Dec 10, 2012 10:29 AM   in reply to greencode75
    use Justify All Lines, check the sample in the link again.
    Dec 10, 2012 11:33 AM   in reply to greencode75
    You seem to be following Wade's suggestion. Try Carlos' one. Create your circle, use the Type-on-a-path tool to add your text and select it. From the Paragraph panel select the right most icon. Worked for me.
    Dec 10, 2012 11:58 AM   in reply to greencode75
    oh, I see, then that example is not good, let me try something else
    Dec 10, 2012 12:02 PM   in reply to CarlosCanto
    Sort of a "hack" method, but you could use dashes (or anything) between sentence words and then set those characters to have a fill of none. Then spaces between sentences.
    Dec 10, 2012 12:27 PM   in reply to greencode75
    Rather than spaces use a chartacter (eg: dash) in between words, that way the forced justication will work.
    Preview mode
    Outline view
    Dec 10, 2012 12:38 PM   in reply to Mike Gondek
    Oh wait I did not see Scott's posting that is the way to go.
    Dec 10, 2012 12:40 PM   in reply to greencode75
    You could also probably create a character style for the dash line and give it a keyboard shortcut. Still a pain but so bad.
    Dec 10, 2012 12:58 PM   in reply to Wade_Zimmerman
    Use En dashed though... option-hyphen. You'll get better spacing between words than you will with a standard hyphen. If you have more than one senetence, use an EM dash after the period (option-shift-hyphen) to get more space between the two sentences.
    Dec 10, 2012 1:49 PM   in reply to greencode75
    or separate the sentences with TABs, then you can eyeball the tab size in the TABS palette, or for precision work, it can be calculated
    Dec 10, 2012 1:49 PM   in reply to Mike Gondek
    That was exactly the answer I was working on (or use kerning instead of hyphens).
    For the finishing touch: use the bracket to adjust the space between the first and the last sentence.
