Hello,
Forgive me if this is an issue for Apple Mac but I'm going to ask here, as well, since it involves Illustrator. I have many nested folders pertaining to one job. (All the contents are Illustrator docs. No matter.) When searching for a previous document or a document within the same nested folder, I can't get Illustrator to immediately access the folder I'm working in. In my case, upon a new search, Illustrator resumes the search starting from the main folder that is nesting the folder I need to get to. Isn't there a way to have Illustrator search the folder where I opened a document previously?
In the finder, I have the preferences set to search from the Current Folder. I've tried all three preferences, including Search Previous Scope and Search This Mac. It remains the same.
Thank you,
Al
I have 12 documents in a nested folder. I am using "command O" to access any or all of those 12 documents. I am not leaving the program to do it (as in the finder's command F). I am simply accessing and reaccessing the documents through Illustrator's "open" command under the File menu. Despite the fact that I am opening documents from the same folder, each time I want to open one of the 12 documents (in case I've closed them) the search window opens up in the Main folder and I must rifle through the same sequence of nested folders to get back to the same spot (the nested folder with the 12 docs).
I don't have the same problem when opening PS documents when using Photoshop. That program's Command "O" brings me back to the folder from where I opened my last document.
Is there a simple preference that will bring me back directly to the folder I am using?
That's the simplest way I can describe it.
Thanks again.
Oh that's an issue across the Mac. You might want to check out Default Folder X (http://www.stclairsoft.com/DefaultFolderX/index.html) it allows you to control open/save locations as well as other features. I've been using it for years becuase the Mac OS has been broken in these terms for many itterations.
North America
Asia Pacific
