Kevin E.
Having issues adjusting objects in template page
Dec 10, 2012 7:17 PM
After grappling with this a couple of days, I could use your help. I have a page I created that I need to make a couple of minor object adjustments. I want to center the flash clock under the rotating photos and move it up so that it does not block the blue shadow. Also, I want to make the "skat news and updates" box below a single box with the news items left justified. Whenever I try to make these adjustments, causes everything else to shift around. Any suggestions on fixing this would be appreciated.
http://www.rideskat.org/index3.html
  • Sudarshan Thiagarajan
    Oct 15, 2010
    Dec 10, 2012 10:19 PM   in reply to Kevin E.
    See if you're okay with this:
    If you are, then what was wrong was that you had re-used floatRT class for almost every element. I guess that class is initially for the Route map & Fares and passes?
    Clock:
    Line 295:
    <span class="floatLT">
    Change that to:
    <div class="flashclock">
    Add to CSS:
    .flashclock{
         float: left; width: 350px; left: 10%; top: -7px; position: relative;
    Bottom area (skat news):
    Line 337 - 343:
    <div id="subcontent">
    <div class="floatLT">
    <h3> </h3>
    <!--end .floatLT --></div>
    <div class="floatRT">
    Remove the lines I've struck off (ideally removing the left floated div with a non breaking space character within <h3>.
    Then, change
    to:
    <div class="skatnews">
    Add to CSS:
    .skatnews{
    width: 100%;
    So now, your Line 337 will become:
    <h3>skat News and Updates</h3>
    <blockquote>
    Another observation, the link colors in 'Skat News...' section is green - making it very difficult to read.
    You may want to change it to a lighter color to suit the background. Maybe the same green you've used as your skat news heading background: #ABD372?
    Trust this helps.
    -ST
    Dec 11, 2012 4:55 PM   in reply to Kevin E.
    This looks familiar!
    Anyway, you have a critical code error that needs attention.
    http://validator.w3.org/check?verbose=1&uri=http%3A%2F%2Fwww.rideskat. org%2Findex6.html
    You're missing a closing </div> for your container.
    Nancy O.
    Oct 15, 2010
    Dec 11, 2012 7:25 PM   in reply to Kevin E.
    Add </div> immediately after <!--end sidebar-->
    </span></div><!--end sidebar-->
    </div>
    That should fix your alignment issue.
    Also, the same line, you have a redundant </span>. It is from before. We're not using that <span> markup now. Remove that.
    The color for 'subcontent' area:
    In the CSS for #subcontent:
    Change this:
    #subcontent {
    clear:both;
    color:#FFF;
    overflow: hidden;
    background-image: url(#085AA4);
    to this:
    #subcontent {
    clear:both;
    color:#FFF;
    overflow: hidden;
    background: #085AA4;
    Good luck.
    -ST
    EDIT: To instruct on removing </span> tag
    Oct 15, 2010
    Dec 11, 2012 11:05 PM   in reply to Kevin E.
    You're welcome
