Construct mx:tree using xml dataprovider
Dec 11, 2012 1:35 AM
Dear All,
     How to construct the tree structure using following xml as dataprovider to mx:tree ?
     The xml is as follows,
<fx:XML id="employees">
     <employees>
         <employee ssn="123-123-1234">
             <name first="John" last="Doe"/>
             <address>
                 <street>11 Main St.</street>
                 <city>San Francisco</city>
                 <state>CA</state>
                 <zip>98765</zip>
             </address>
         </employee>
         <employee ssn="789-789-7890">
             <name first="Mary" last="Roe"/>
             <address>
                 <street>99 Broad St.</street>
                 <city>Newton</city>
                 <state>MA</state>
                 <zip>01234</zip>
             </address>
         </employee>
     </employees>
</fx:XML>
    Dec 12, 2012 7:35 AM   in reply to Supreet R
    you need to pass an xmlist (rather than xml) to the tree.
    from my distant memory, something like this should work:
    tree.dataProvider = new XMLList(employees.toString());
    tree.labelField = "@ssn";
    Dec 13, 2012 3:44 AM   in reply to Supreet R
    Hi Supreet,
    I see above XML is not correct to display what you want to display
    Beacuse <street>11 Main St.</street> considered as parent node.
    as per my understanding from above code ,You want first street should be displayed, and in leaf node street name should be there(child item).
    you can modify your existing code as,
    1.XML
                        <address>
                            <street str= "street">
                                <streetname street="11 Main St."/>
                            </street>
                            <state>CA</state>
                            <zip>98765</zip>
                        </address>
                    </employee>
    2.getTreeLabel method
    case "address":
                            lbl = item.name();
                            break;
                        case "street":
                            lbl = item.@str;
                            break;
                        case "streetname":
                            lbl = item.@street;
                            break;
                        case "city":
    Kanchan Ladwani | kladwani@infocepts.com
