Is it possible to add a Description Column in the Content Panel. If so, how?
I'm talking about the Description from the IPTC Core data and I'm using Bridge CS5.
Thanks in advance,
Frank
You can have Bridge display IPTC Description in its Metadata Panel/Tab (along with IPTC lines such as Document Title, Keywords, Author, ...) under IPTC (IIM Legacy) and IPTC Core. In Bridge: Edit > Preferences > Metadata and check Description under IPTC (IIM Legacy) or IPTC Core (or both).
Thanks for the suggestion. I did this but nothing changed. I'll try to explain more. My question is about the content panel, not any other panel. It's the default panel in my bridge version what normaly shows:
My question is about the last mode "Metadata" and the content panel. This data is shown in columns and you can select the columns that you want to see. The only thing I want to do is show the description in a column just like keywords etc. The result would be that you can see the description in the list in the content panel of all the files within that folder.
I think you are confusing Workspace with Content Panel.
Each panel has a tab which lables it. Where I am getting hung up is the Content Panel contains the thumbnails and may show keywords, filename, etc. depending on options chosen in View and preferences/thumbnails. It can also just show thumbnails, list, or details.
Maybe a screen shot of what you are thinking of would be of help. Like Robert says you can add Description in Metadata Panel, or like I suggested you can add Descripton under image, but you can not create another panel without some fancy programing as far as I know.
I think Frank means the content panel from the metadata workspace, and he is right to expect that option there but as many of the default workspaces it is next to useless ![]()
You can not enter the description field in this workspace because it is just (yes I know, it sounds unbelievable but sadly enough this is true...) not in the list and not possible to add.
Also adding a column in this workspace is far from easy. In short, the concept of this Metadata workspace is brilliant, the result a disaster...
Thanks Curt, but that's not what I'm looking for. I think it's just not possible like Omke and Paul said.
This is the screenshot of the Metadata Workspace with the Content Panel (not Metadata Panel). As you can see it shows Name, Label, Keywords etc. but it's not possible to show Description in that list as a column.
Frank
I still agree that it would be a big bonus if you could alter this workspace with description field (even with more lines etc) but what Curt shows you might be an alternative. I couldn't help noticing that you have not created your own custom workspaces.
Try and play with this. You have the option to divide the window in 3 columns max but you can create different panels as a row in 1 column.
Grabbing a tab and move it to a new location until a single blue line appears (between the borders, a bit tricky). A vertical blue line means as a column and a horizontal line means a row. A surrounding blue line means same panel but adding as a tab. You can rearrange the tabs by dragging to left or right. under the menu window you can select which panels are visible or use right mouse click menu on top of a panel to choose.
Sadly enough only 3 columns and only one panel of it's kind per workspace, but you can resize the panels also to your own workflow needs.
In Bridge preferences you can change the colors for background in the general tab and in the metadata tab you can select what info to view in certain sections. Personally I have set my IPTC to view only description, keywords, date created and a few other subjects.
That is the nice thing about Bridge, creating custom workspaces, save them and being able to recreate them without problems :-)
I attach some screenshot of my daily workflow (with the luxury of having a 30' screen) but there are plenty of other options possible, don't forget to name and save your workspace.
North America
Asia Pacific
