Adobe Illustrator CS6 Update (version 16.0.3)
Installation failed. Error Code: U44M1P7
Photoshop update work fined.
Macintosh running Mountain Lion.
Same thing here. Have you tried uninstalling Illustrator and reinstalling from Application Manager? If so, any luck?
I hope it's not the same thing these poor folks had to (are) deal with: http://forums.adobe.com/message/4618444
Please update the AAM to the latest version before applying the patch. It could be found at :-
Win - http://www.adobe.com/support/downloads/detail.jsp?ftpID=4773
Mac - http://www.adobe.com/support/downloads/detail.jsp?ftpID=4774
Nishant
Update: it only appears to make actions play twice if they're invoked from an F-key.
This is completely unacceptable. Will Adobe compensate me for the inefficiency this creates in my workflow? My billable time is based on being able to complete jobs in carefully calculated timescales and this REALLY messes with that.
I only installed this update in hope it would fix the broken window behaviour under Mountain Lion, which I reported with the initial release and which remains unaddressed.
Seriously this is getting obnoxious, everytime an update is released it fails and I end up having to uninstall and reinstall the software, if that even works. If this continues I am going to uninstall and forget about reinstalling all together. Not to mention, the sudden push to suscribe users to the Creative Cloud and including features in that end of the software that aren't being included in the versions other license holder are entitled to. How about some quality control and some integrity!
Heh. I'm still trying to work out how the 16.0.3 update can be issued under "bug fixes" when it's fixed no visible bugs for me, but introduced two new ones that are catastrophically disruptive to my workflow (actions rendered unuseable from Fkeys, no color profiles embedded in exported TIFFs)…
Not only did it not update, I get a Twitter response from someone named Madison at Adobe_Care:
Adobe Customer Care (@Adobe_Care)
@MarkWRoberts11 Hi Mark, we're sorry about that. You can try solution #2 here: forums.adobe.com/message/479431… ^Madison |
Then to add to my fun, after deleting the Extension Manager and following the direction on the Adobe site, Illustrator Crashes !!! Now I have nothing working... so I trash EVERYTHING CS6, and just figure I'll "re-install clean..."
I can't even do that !!! AAM says everything is still installed... I'm looking for a .plist file or cache to delete... anyone? This is on my MBPwR thank god my iMac still works normally... still can't get two of the updates, but I'll live with that for now...
What a mess...
Nothing is working except InDesign.
This is what I see:
Adobe Illustrator [2452]
Path: /Applications/Adobe Illustrator CS6/Adobe Illustrator.app/Contents/MacOS/Adobe Illustrator
Identifier: com.adobe.illustrator
Version: 682 (16.0.0)
Code Type: X86-64 (Native)
Parent Process: launchd [199]
User ID: 501
Date/Time: 2012-12-12 14:08:56.417 -0500
OS Version: Mac OS X 10.8.2 (12C60)
Report Version: 10
I open to all suggestions
...well, I took everything out of the trash, and placed it back into the Applications folder, I used the Illustrator "Un-installer" and finally got AAM to recognized that it wasn't installed... so I am now re-installing Illustrator Only as a test to see if that solves the "temporary problem."
I am semi-fortunate, I don't use all of the CS6 Suite of applications, but wouldn;t you know it's always the ones I NEED that fail?!?!! AI, PS, FW, DW, and ID are my main tools...
*** update, that worked, I am back to running Illustrator 16.0.0 *** at least no crash... going to check a few of the others to see if they still work...
I too had the exact same problem, all the solutions above are simply time wasters. (i.e. read error logs and installing Adobe Support Advisor, really? I have to do all that because of a simple upgrade?) Hopefully Adobe will remedy this problem very soon.
Yes, reinstalling via Time Machine worked for me too. It has the be the installer hosing up the app.
Same problem here - is anybody else using MacKeeper? I've heard that it is the culprit - deletes a .plist file that is required to update Illustrator. Have no idea which one, or why, or how to fix it. I hope Adobe weighs in here...if this is the case and they are aware of it, could they perhaps post a link with instructions on replacing it?
Same Problem :-( MacBook Pro and using MacKeeper - All other CS apps open/work EXCEPT Illustrator which the program that I do 95% of my work in! NOT a happy camper right now.
Extension Manager 6.0.4 Update
Hello All,
So the deed is done, I have isolated the problem to be MacKeeper's Fast Cleanup function. I am not sure, which file it is that it deletes that causes this, but I am sure that once you run it Adobe CS6 Illustrator update will fail. I've uninstalled Illustrator when the update failed and reinstalled it and was able to perform the update successfully. Then in an attempt to isolate this problem I uninstalled Illustrator again and then reinstalled it, but prior to running the update I ran the Fast Cleanup function on MacKeeper and what do you know the update failed again. I have been in contact with Trey from MacKeeper support, who remains interested in getting all the details to get this resolved on their end. He did refund my order and left my license active for a year, which I found to be ok. Although, I am not sure exactly what to do with that given that I wont be using it to prevent this from happening.
Rich
I have the same problem. Dreamweaver's update installed fine though. I don't even know what MacKeeper is.
Photoshop 13.1 for Creative Cloud
Here's my list of installed applications:
cd /Applications
ls
./ Dashboard.app/ Preview.app/
../ Dictionary.app/ QuickTime Player.app/
.DS_Store Divvy.app/ QuikIO.app/
.localized Dropbox.app/ Reminders.app/
1Password.app/ Droplr.app/ Remote Desktop Connection.app/
Adobe/ Espresso.app/ Safari.app/
Adobe Bridge CS6/ Evernote.app/ Sauce.app/
Adobe Dreamweaver CS6/ FaceTime.app/ Sip.app/
Adobe Edge Code Preview.app/ Firefox.app/ Skitch.app/
Adobe Edge Inspect.app/ Flux.app/ Skype.app/
Adobe Extension Manager CS6/ Font Book.app/ Spotify.app/
Adobe Illustrator CS6/ Found.app/ Stickies.app/
Adobe Muse.app/ FreeMemory Pro.app/ Sublime Text 2.app/
Adobe Photoshop CS6/ Game Center.app/ SugarSync.app/
Adobe Photoshop Lightroom 4.app/ Geekbench.app/ Suitcase Fusion 4.app/
Adobe Revel.app/ GitHub.app/ SuperDuper!.app/
Alfred.app/ GitX.app/ System Preferences.app/
Amazon Cloud Drive.app/ Google Chrome Canary.app/ TextEdit.app/
Android Apps@ Google Chrome.app/ TextMate.app/
Anvil.app/ Hammer Trial.app/ Time Machine.app/
App Store.app/ Image Capture.app/ Tower.app/
AppCleaner.app/ ImageOptim.app/ Transmit.app/
Archive Utility.app* Kindle.app/ Twitter.app/
Automator.app/ Last.fm.app/ Ubuntu One.app/
Backblaze.app/ Launchpad.app/ Utilities/
Bartender.app/ LightTable.app/ VirtualBox.app/
Brackets Sprint 16.app/ LiveReload.app/ WebFonts/
Brackets Sprint 17.app/ MacVim.app@ WebKit.app/
Brightness Slider.app/ Mail.app/ WebStorm.app/
CCleaner.app/ Messages.app/ Wi-Fi Diagnostics.app*
Calculator.app/ Microsoft Communicator.app/ Windows Phone.app/
Calendar.app/ Microsoft Messenger.app/ Woven Uploader.app/
Carbon Copy Cloner.app/ Microsoft Office 2011/ Xcode.app/
Charles.app/ Microsoft Silverlight@ Xcode46-DP1.app/
Chess.app/ Mission Control.app/ Xcode46-DP2.app/
Chocolat.app/ Mou.app/ Xmarks for Safari.app/
Chromium.app/ MyShoebox.app/ eclipse/
Coda 2.app/ NetNewsWire.app/ iOS Simulator.app@
CodeKit.app/ Notes.app/ iPhoto.app/
Colloquy.app/ Opera Mobile Emulator.app/ iTerm.app/
ColorSchemer Studio 2.app/ Opera Next.app/ iTunes.app/
ColorSchemer Studio.app/ Opera.app/ iWork '09/
Contacts.app/ Photo Booth.app/
DVD Player.app/ Pocket.app/
North America
Asia Pacific
