I am having problems applying the Illustrator 16.2 update
Dec 11, 2012 11:47 AM
This thread has been created for users facing difficulties applying the Illustrator 16.2 update.  Please begin by reviewing your installation logs to attempt to locate the point of failure.  You can find details on how to locate and interpret your installation log at Troubleshoot with install logs | CS5, CS5.5, CS6 -http://helpx.adobe.com/creative-suite/kb/troubleshoot-install-logs-cs5 -cs5.html.
If you need assistance with reviewing your log please utilize the Adobe Support Advisor - http://www.adobe.com/support/loganalyzer/ and choose the package for support option.  If you can then respond to this thread with the operating system you are using and your token number a Adobe employee can then assist with reviewing your installation logs.
Branched to a new discussion.
    Dec 11, 2012 11:20 AM   in reply to Jeff A Wright
    fix the first link
    Dec 11, 2012 4:12 PM   in reply to Jeff A Wright
    Please help. Running in a MAC token: 40-73477-153011122012
    Dec 12, 2012 3:12 PM   in reply to Jeff A Wright
    Actualización de Adobe Illustrator CS6 (versión 16.2.0)
    Error de instalación. Código de error: U44M1P7
    Dec 17, 2012 1:04 AM   in reply to Jeff A Wright
    Good morning,
    I have trouble installing the 16.2.0 update as well. I ran Adobe Support Advisor and here is the token returned by the application:
    40-23495-024416122012
    Other applications have been updated without problems. ASA tells me that there's a problem with validation of the pre-chrome licence (translated from French, I hope you see what it means). It seems to have a link with Creative Suite 5. I'm a bit surprised as I uninstalled CS5 as cleanly as possible (using the maccs5clean script).
    I'm working on a 17" MacBook Pro (Early 2011) with Mac OS X 10.8.2.
    Regards,
    Damien
    Message was edited by: Shralldam (added operating system).
    Dec 18, 2012 7:27 AM   in reply to Jeff A Wright
    Hi Jeff,
    I uninstalled Illustrator then installed it again, and the update went fine. Thank you very much!
    I recently replaced my internal hard disk with a SSD and needed to optimize space occupied by applications, so I ran an utility that strips unneccessary code from programs. Apparently it's the reason why Illustrator couldn't update itself, as you said.
    Thank you again for yoyr help,
    Damien
    Dec 18, 2012 10:18 AM   in reply to Jeff A Wright
    I used XSlimmer from LateNiteSoft.
    There's a blacklist inside the app that prevents to run it on software known to be broken after the "shrink" process. Illustrator CS6 wasn't it the list… Maybe they should update it.
    Regards,
    Damien
