Liquify as a Smart Filter Issue in Photoshop Creative Cloud edition
Dec 11, 2012 12:25 PM
Tags: #object #cs6 #smart #liquify
Liquify as a Smart Filter is definitively a long waited feature but I found an issue with it.
I made smart object from a layer, applied Liquify, next I change the document ratio with Crop tool...You see, completely different pixels are liquified now. Dissapointing
I've reported the issue already.
  • JJMack
    Jan 9, 2006
    Dec 11, 2012 1:23 PM   in reply to YahorShumski
    Why that is how smart filters work. When you Change a document smart filter are them redone. If you change the document aspect ratio deleting some content I can well imagine trying to apply a filter like Liquify may well be a mess.  No real harm has been done its a nondestructive edit just readjust the setting or discard the smart filter and add a new one you do for the documents new aspect ratio and the layer different content. If you do not want that to happen rasterzise the smart object layer before you crop apply the Liquify..
    Dec 11, 2012 9:57 PM   in reply to YahorShumski
    Maybe you could post some screenshots and more details, like what you did with the crop tool. (settings)
  • Noel Carboni
    Dec 23, 2006
    Dec 12, 2012 6:29 AM   in reply to YahorShumski
    I'm having trouble understanding why you would think that should work.
    Liquify manipulates pixels based on a set of distortions called a "mesh".  Pixel position manipulation instructions stored in this mesh decidedly must contain pixel position information
    Changing the canvas size changes the number of pixels in the document, and thus how the position information would apply, I should think.
    Adobe would have to re-map the position information if the same mesh is to be applied to a different-sized document.  How they do this I don't know, but I can imagine it might be centered or stretched across the image, but I wouldn't expect it to be stuck into the upper-left corner.  Do you have information that says it should?
    What happens if you increase the canvas size equally all the way around>
    -Noel
    Dec 12, 2012 7:51 AM   in reply to YahorShumski
    I don't think it's technically difficult to extend mesh the same side as document.
    On what experience do you base that assumption?
    When you save a Liquify Mesh, then cange the Canvas Size of the document and try to use the Mesh again it seems obvious to me that this will cause a dissonance.
    I do not use the Cloud License so I don’t have access to that feature yet, but have you tried converting the Liquified SO to an SO before messing with the Canvas Size?
  • JJMack
    Jan 9, 2006
    Dec 12, 2012 8:15 AM   in reply to YahorShumski
    I think the layer is the same size as it was before the canvas was added and the pixels are the same a square block box on white rectangle size you can test that by turning off the visibility of the liquify smart filter. I'm not on the cloud cant test.  The mesh was resized for the new canvas size and has a new size.   The recorded setting for the filter are for the old mesh size.  The mesh was most likely resized correctly for the new canvas size.  However the setting you made were not for that mesh the recorded settings saved in the smart filter are for the old mesh. The old mesh no longer exists the canvas size has changed. Perhaps you can use Liquify advance mode and save the old mesh before changint the canvas size. I do use liquify much and can not use it as a smart filter.
  • JJMack
    Jan 9, 2006
    Dec 12, 2012 8:40 AM   in reply to YahorShumski
    Even if you save the mesh before the canvas size change can the mesh be loaded for the new canvas size. Canvas size can add and remove canvas. How would one align the old mesh to the size the mesh now must be.
    Using Image Size not constraned might me able to distort all layers like you transformed you liquified layer.
  • Noel Carboni
    Dec 23, 2006
    Dec 12, 2012 8:33 AM   in reply to YahorShumski
    Only thing I might suggest as a workaround for now is working on your entire image (uncropped) as the master, then cropping at the end when you're making your work products.
    -Noel
    Dec 12, 2012 8:35 AM   in reply to YahorShumski
    I think the underlying issue is that increasing a dimension of the canvas by using Crop Tool or Image > Canvas Size results in a Smart Object being scaled unlike other layer types which are unaltered. Scaling a SO results in Smart Filters being recalculated.
    In contrast, decreasing a canvas dimension by cropping or canvas-sizing does not result in SO scaling and a Smart Filtered SO is unchanged.
    Therefore, I think the scaling of SO when a canvas dimension is increased is wrong. Fix that and Smart Filter Liquify and others should not be affected by change of canvas size.
    Dec 12, 2012 8:39 AM   in reply to YahorShumski
    I can hide Liquify smart filter before cropping but it doesn't affects the final result.
    Nothing to do with what I meant.
    Converting the Liquified SO to an SO should fix its Canvas Size, so the Liquify Smart Filter might be maintained properly on an SO in an SO – but if the Canvas Size of the new SO is the old SO’s Layer Bounds then it probably would be no use.
    I relatively often use SOs in SOs etc. …
    If, on changing the Canvas Size, Photoshop should check all SOs in the document for applications of Liquify that might add a (slight) drag on the operation.
  • Noel Carboni
    Dec 23, 2006
    Dec 12, 2012 8:41 AM   in reply to conroy
    Perhaps I'm not understanding you, Conroy...  Doesn't that kind of fly in the face of what Yahor showed in his video?  He increased the canvas size to the right and the square just sat there the same size and shape, with new transparency showing up on the right.
    I've not been able to see a Smart Object scale with changes to the Canvas Size myself.  Maybe I'm not doing what you're suggesting...
    -Noel
  • JJMack
    Jan 9, 2006
    Dec 12, 2012 9:12 AM   in reply to conroy
    Increasing canvas size does not scale smart objects.  The smart layers embedded object has not changed, only its associated transform position has been adjusted for the new canvas size. The Op saw that when I suggested he turn of the liquify smart filters visibility. What is happing is the liquify smart filter is using s different mesh after the canvas has been resized so its results are different then before the canvas resize.
    Yes unlike other type of layers where cropping with crop tool or canvas size these layers mat have pixels removed and in the case of the background layer may have pixels added. Smart layer embedded object remain intact only the associated transform position is adjusted for the new canvas size
    Dec 12, 2012 9:27 AM   in reply to Noel Carboni
    -Noel
    I didn't notice the video, unfortunately.
    I happened to be using Lens Correction on a SO when posting. You're correct, normally SO are unscaled by a change in canvas dimension. I wrongly extrapolated that all SO would be scaled because a Lens Correction Smart Filtered SO does scale when a canvas dimension is increased. A simple example follows.
    Before activating Crop Tool
    Increased canvas width before committing crop.
    After committing crop, the SO is wider plus its image is upscaled.
    Dec 12, 2012 9:42 AM   in reply to JJMack
    JJMack wrote:
    Increasing canvas size does not scale smart objects. [...]
    I now see you're right about most Smart Objects. However, what do you make of my example of a Lens Correction Smart Filtered Smart Object being upscaled?
    Yes, I've always understood that the object embedded inside a SO is always unchanged by operations in the main document.
  • Noel Carboni
    Dec 23, 2006
    Dec 12, 2012 10:31 AM   in reply to conroy
    Seems like the same thing that Yahor reported - that the filter is scaling its operation to the entire visible canvas.
    -Noel
    Dec 12, 2012 10:33 AM   in reply to Noel Carboni
    In my case, the actual SO has its dimensions changed.
  • Noel Carboni
    Dec 23, 2006
    Dec 12, 2012 10:55 AM   in reply to conroy
    Considering that Lens Correction can expand an image (even a non-SO image), does it change the dimensions of the SO if you dial in center-scale settings in the Lens Correction tool?
    -Noel
    Dec 12, 2012 11:13 AM   in reply to Noel Carboni
    Yep, the SO is enlarged when scale is minimum in the filter controls. As before, the images are before crop, during crop before commit, and after crop. Note that after the crop, the checkered pattern is definitely larger despite not entirely filling the enlarged hole in the black surround.
    Dec 12, 2012 4:55 PM   in reply to conroy
    The first time Liquify starts it tests to see if it was invoked as a smart object or from an action. If so, when finished,  it returns the current mesh in an action descriptor that is included in the smart object or action. When Liquify is restarted as a smart object the mesh is loaded from the action descriptor and scaled vertically and horizontally to fit the current document size, not the image size within the document.
    Dec 12, 2012 11:17 PM   in reply to jworthin
    So if a Smart Object has other, smaller bounds than the document’s canvas size is the Mesh the size of the Layer or the Document?
    In any case I think the important thing is that a longstanding feature request has been implemented (even if it is currently limited to the … Cloud), so: Thanks!
    Dec 13, 2012 9:08 AM   in reply to c.pfaffenbichler
    Currently the mesh is resized to the document bounds.
    If we added capability, how could Liquify know if the user wanted to see the entire document bounds or just the layer bounds? Does it matter? Could Liquify only show the layer bounds and not the document bounds in future versions? Would this negatively affect any other user work flows?
    What if Liquify was to detect a change in the (document or layer) bounds relative to the loaded SO mesh and pop a dialog asking the user how to handle the change, ie scale the old mesh to fit, fill new areas with new mesh, or ??
    Thoughts?
  • Noel Carboni
    Dec 23, 2006
    Dec 13, 2012 4:12 PM   in reply to jworthin
    That pop-up you mentioned at first blush sounds like a decent way to handle it.  Something along the lines of the Canvas Size dialog.  You could even have it default to certain settings if it's possible to detect specifically how the canvas size was changed.
    ON THE OTHER HAND...
    One has to wonder, though, especially if there are more filters that need this treatment (e.g., Lens Correction) whether a person might see pop-up after pop-up, each time a canvas size is adjusted via the Crop Tool.  That wouldn't be good.
    -Noel
    Dec 13, 2012 10:29 PM   in reply to jworthin
    I think that makes sense.
    Could this cause issues with Smart Objects that extend beyond the document’s canvas?
    And if a SO with Liquify applied is converted to a SO will the resulting SO be of the document size?
    Thoughts?
    Apart from changed canvas’ sizes I’m afraid that transformations of the Smart Object itself might cause mixed expectations; some users may expect the Mesh to be transformed along with the SO (which I supsect might be difficult in case of a Warp) while others may expect the Mesh to stay put.
    In any case I highly welcome the implementation of the feature.
