Css Transition
Dec 11, 2012 12:44 PM
Tags: #cs5 #error #html #css #layout #html5 #css3
HI
I want to add a transition like this: http://tv.adobe.com/watch/cs6-creati...eamweaver-cs6/
html
<div id="webDesign">
<div class="contentinformation" id="contentinformation">
<h2>Cheap Website Design</h2>
<p>Cheap web design from £89.99 for 1 page</p>
</div>
<br />
</div>
css
#webDesign {
background-image : url(../images/web-design.jpg);
background-repeat : no-repeat;
float : left;
height : 143px;
width : 220px;
overflow : hidden;
.contentinformation {
background-color: #000;
color: #FFF;
margin-top: 100px;
text-align: center;
font-weight: bold;
padding-top: 1px;
opacity:0.8;
filter:alpha(opacity=80); /* For IE8 and earlier */
-webkit-transition-property: top, bottom;
-webkit-transition-duration: 0.5s;
.contentinformation:hover {
top:0px;
bottom:0px;
Thanks in advance for any help
    Dec 11, 2012 12:50 PM   in reply to Daniel Waddon
    A -webkit-transition will only work on Chrome and Safari.
    You also need the following to ensure maximum cross browser goodness...
    -webkit-transition: (for safari and chrome)
    -moz-transition: (for firefox)
    -o-transition: (for opera)
    transition: (for when they all switch after css3 is turned into the standard)
    Here is a good reference page for the transition shorthand (I never separate them out anymore)...
    http://www.w3schools.com/css3/css3_transitions.asp
    Dec 11, 2012 1:13 PM   in reply to Daniel Waddon
    Intro to the CSS Transitions Panels in DW CS6:
    http://www.adobe.com/devnet/dreamweaver/articles/css-transitions-panel .html
    Nancy O.
    Dec 11, 2012 1:35 PM   in reply to Daniel Waddon
    You also need to define the "to" states for all of the attributes you want to change from .contentinformation to .contentinformation:hover
    For example, if you want the background color to change, both classes need to have a background-color defined.
    Dec 11, 2012 1:47 PM   in reply to Daniel Waddon
    What I mean is if you want...
    color: #FFF;
    margin-top: 100px;
    text-align: center;
    font-weight: bold;
    padding-top: 1px;
    -webkit- opacity:0.7;
    -moz-opacity: 0.7;
    opacity:0.7;
    filter:alpha(opacity=70); /* For IE8 and earlier */
    to change when you hover over it as ...
    -webkit-transition: all 1s linear 0.5s;
    -moz-transition: all 1s linear 0.5s;
    -ms-transition: all 1s linear 0.5s;
    -o-transition: all 1s linear 0.5s;
    top: 0px;
    bottom: 0px;
    Implies, you need to define all of the attributes for the :hover version that you want changed when hovered. Right now, you have nothing defined on .contentinformation:hover except a top and bottom attribute (that are likely unnecessary). The transition can't happen because you have not defined the color, background-color, etc for the :hover. You should have something like...
    background-color: #fff;
    color: #000;
    margin-top: 100px;
    text-align: center;
    font-weight: bold;
    padding-top: 1px;
    -moz-opacity: 0.7;
    opacity:0.7;
    For the .contentinformation:hover style. If you want it to transition back when you mouse out of the div, you also need to add the transitions to the end of the .contentinformation class as well
    Dec 11, 2012 2:03 PM   in reply to Daniel Waddon
    Almost there.
    Now all you need to do in the .contentinformation:hover class is change your settings to make the transition go "from" the settings in .contentinformation "to" the settings in .contentinformation:hover when the mouse moves in.
    Keep in mind, none of this works in IE9 or lower.
    Dec 11, 2012 2:13 PM   in reply to Daniel Waddon
    You need to change the values of the attributes in .contentinformation:hover so the transition can move from one value to the next.
    In your current code, you have "background-color:#000;" in both the .contentinformation and .contentinformation:hover classes (as well as opacity settings and color settings). On :hover it would be transitioning from the hex color #000 to #000 which is the same color and not a very exciting transition.
    Change the attribute values from one class to the next so the transitions moves from something to something else.
    A good set of tutorials for basic css is available here: http://www.w3schools.com/css/default.asp
    Once you have the basics of css down, you can add in css3 (which includes transitions) here: http://www.w3schools.com/css3/default.asp
    Dec 11, 2012 2:31 PM   in reply to Daniel Waddon
    You can do it from the CSS Styles Window.
    Go to Window > CSS Styles
    In the window that comes up, click "All" then the style you want to change. Make changes in the bottom half of the window. Depending on your version of DW, some attributes may not show up in that window and will require some hand adjusting in the source.
    Dec 11, 2012 2:33 PM   in reply to Jon Fritz II
    -webkit-transition and transition are all that is necessary. The last
    several versions of Firefox support the standard as does Opera and IE10.
    Only Safari and Chrome need the vendor prefix.
    Al Sparber - PVII
    http://www.projectseven.com
    The Finest Dreamweaver Menus | Galleries | Widgets
    Since 1998
    Dec 11, 2012 2:36 PM   in reply to Daniel Waddon
    The transition goes on the default element. All that goes on hover is
    the properties that you want to transition. With "All" set, all
    properties on the hover will be animated if they are different from
    those on the default element. Here is a working example running on a
    prototype page for an upcoming PVII widget:
    http://www.projectseven.com/products/tools/accordion3/demos/base.htm
    View the CSS.
    Al Sparber - PVII
    Since 1998
    Dec 11, 2012 3:18 PM   in reply to Daniel Waddon
    CS5 does not support CSS3 transitions in the panels. You need to code
    this manually in your CSS file.
    Al Sparber - PVII
    Since 1998
    Dec 11, 2012 6:21 PM   in reply to Daniel Waddon
    I don't use the browser for this forum... I use email and I cannot send
    any type of code.
    The "transition" property does not go on the "contentinformation hover"
    rule. It goes on the "contentinformation" rule. The "all" value means
    that the browser will look for all properties common to both rules and
    animate those with different values. It's really quite simple. What
    don't you understand?
    Al Sparber - PVII
    Since 1998
    Dec 12, 2012 1:23 AM   in reply to Daniel Waddon
    If you do not want to learn then stop posting. I explained how it works.
    Why are you arguing?
    Al Sparber - PVII
    Since 1998
    Dec 12, 2012 6:42 AM   in reply to Daniel Waddon
    Danny, you need to understand that this is a user-to-user forum and the people here are just designers and developers with a generally helpful disposition. Very few of the people here are Adobe emplyees and even fewer (if any) are trained to handle dyslexia in an educational environment.
    From what I understand, we're all going to need to be a little more patient.
