allieybender
Photoshop will never go to the background
Dec 11, 2012 7:15 PM
Unless I hide it. I've never had an issue before with CS3 and CS4.  When I clicked out of photoshop, i was in the program behind it.
http://screencast.com/t/K6Y1NWVP
    Dec 11, 2012 8:00 PM   in reply to allieybender
    In photoshop go to Window and uncheck Application Frame
    Dec 11, 2012 9:14 PM   in reply to allieybender
    I can't work without it: to each their own.
    Dec 12, 2012 3:54 AM   in reply to KimberlyGabriel
    I prefer to enable the AF, too. Unlike the OP, having it enabled does not prevent other apps moving in front of Ps when I switch app on OS X 10.6.8.
    Dec 12, 2012 6:54 AM   in reply to allieybender
    I can reproduce this by doing the following:
    - Run Google Chrome
    - Run Photoshop
    - Use the application frame
    - Have one or more floating windows
    - With Photoshop in the foreground click on the chrome window title bar
    Result: The Chrome window end up under the floating Photoshop window
    When I drag Chrome, it properly moves to the front.
    I am only able to reproduce this with Chrome. Mail, Safari, Firefox all work as expected.
    I this what you are seeing?
    Dec 12, 2012 7:29 PM   in reply to allieybender
    Thank you for confirming that this issue is specific to using Google Chrome.
    It looks like you are solving this issue by not using the application frame. Another option is to use command+tab to switch between the applications. We will investigate the issue further.
    Dec 12, 2012 8:39 PM   in reply to Jesper Storm Bache
    The good news is that you got the attention of exactly the right engineer to work on that issue :-).
    Dec 15, 2012 1:24 PM   in reply to allieybender
    Hello,
    I'm not sure if my problem is similar tothis one:
    http://forums.adobe.com/message/4923337#4923337
    I use Safari as my browser.
    What is happening is that when I have several photos currently open, some of them will end up behind the screen, after I move them around on my screen (e.g. to access one behind the other).
    They keep disappearing, and I have to constantly go to Window >>>Arrange >>> Consolicate All to Tabs or Float All in Windows.
    Can you help?
    SB
