I have set up a spry menu in my page. file:///C:/Users/Kim/Documents/PQH_xhtml/index.html
Everything works great in Chrome and Firefox. Just not in IE. The only problem I am having is in IE the drop down menus stretch out all the way across the page.
I have tried changing the width, but it messes up Chrome and Firefox. Just need IE to shorten up the width of sub menus.
Any help is GREATLY appreciated!!!
Thank you very much! This setting in the style rules has stopped the drop down submenus from going across the whole screen. I was wondering...is there any way that I can get IE to have the same drop down width as the Chrome and Firefox? Those sub menus drop down wonderfully, the same size as the main menu button. Just wondering. Again, thanks for your help.
Help :[ Okay, so the Spry Menu Bar is looking and seems to be working okay except for a couple of tweeks. I have looked all over and just need a quick
tip from someone who is more experienced than I with Dreamweaver and coding.
In Google and Firefox, width of the drop down menu boxes is great, however the text goes beyond the box. At one time, I had it so the text continued onto the next line and the box height adjusted accordingly. That way the drop down boxes were all still the same as the parent (main) box.
In IE the text is all in the dd box, but the boxes are different widths to accomodate the text. Again, like above, I would like to have the text continue on to the next line and the box height adjust as needed. All my drop down boxes should be the same width as my main menu button (box).
I am not sure how to show it here, since it is still only a work in progress on my computer.
Any help will be greatly appreciated!!!
The answer to your problem can only be found in the code (HTML, CSS and JS).
The out-of-the-box SpryMenyBar works well. It is when one makes changes in the code that the problems arise. Have a look here
http://www.dwcourse.com/dreamweaver/ten-commandments-spry-menubars.php #one
May I assume that you have made no changes in the JS file and that the changes in the HTML file will not cause the problems. In which case, the problem probably lies in the CSS. It will therefore be a good idea to copy and paste the CSS file in your next reply.
This is the styles.css
@charset "utf-8";
/* Simple fluid media
Note: Fluid media requires that you remove the media's height and width attributes from the HTML
http://www.alistapart.com/articles/fluid-images/
img, object, embed, video {
max-width: 100%;
/* IE 6 does not support max-width so default to width 100% */
.ie6 img {
width:100%;
Dreamweaver Fluid Grid Properties
dw-num-cols-mobile: 4;
dw-num-cols-tablet: 10;
dw-num-cols-desktop: 15;
dw-gutter-percentage: 15;
Inspiration from "Responsive Web Design" by Ethan Marcotte
http://www.alistapart.com/articles/responsive-web-design
and Golden Grid System by Joni Korpi
http://goldengridsystem.com/
/* Mobile Layout: 480px and below. */
.gridContainer {
margin-left: auto;
margin-right: auto;
width: 96.7391%;
padding-left: 1.6304%;
padding-right: 1.6304%;
background-color: #f9f8f6;
#LayoutDiv1 {
clear: both;
float: left;
margin-left: 0;
width: 100%;
display: block;
#navigation {
clear: both;
float: left;
margin-left: 0;
width: 100%;
display: block;
#exterior_pic {
clear: both;
float: left;
margin-left: 0;
width: 100%;
display: block;
#welcome {
clear: both;
float: left;
margin-left: 0;
width: 100%;
display: block;
#interior_pic {
clear: both;
float: left;
margin-left: 0;
width: 100%;
display: block;
#bottom_nav {
clear: both;
float: left;
margin-left: 0;
width: 100%;
display: block;
#footer {
clear: both;
float: left;
margin-left: 0;
width: 100%;
display: block;
/* Tablet Layout: 481px to 768px. Inherits styles from: Mobile Layout. */
@media only screen and (min-width: 481px) {
.gridContainer {
width: 98.6956%;
padding-left: 0.6521%;
padding-right: 0.6521%;
#LayoutDiv1 {
clear: both;
float: left;
margin-left: 0;
width: 100%;
display: block;
#navigation {
clear: both;
float: left;
margin-left: 0;
width: 100%;
display: block;
#exterior_pic {
clear: both;
float: left;
margin-left: 0;
width: 100%;
display: block;
#welcome {
clear: both;
float: left;
margin-left: 0;
width: 100%;
display: block;
#interior_pic {
clear: both;
float: left;
margin-left: 0;
width: 100%;
display: block;
#bottom_nav {
clear: both;
float: left;
margin-left: 0;
width: 100%;
display: block;
#footer {
clear: both;
float: left;
margin-left: 0;
width: 100%;
display: block;
/* Desktop Layout: 769px to a max of 1232px. Inherits styles from: Mobile Layout and Tablet Layout. */
@media only screen and (min-width: 769px) {
.gridContainer {
width: 99.1304%;
max-width: 1232px;
padding-left: 0.4347%;
padding-right: 0.4347%;
margin: auto;
#LayoutDiv1 {
clear: both;
float: left;
margin-left: 0px;
width: 98%;
display: block;
border-top-width: 10px;
border-right-width: 10px;
border-bottom-width: 10px;
border-left-width: 10px;
border-top-style: double;
border-right-style: double;
border-bottom-style: none;
border-left-style: double;
border-top-color: #3b87d5;
border-right-color: #3b87d5;
border-bottom-color: #3b87d5;
border-left-color: #3b87d5;
margin-top: 10px;
margin-right: 1px;
padding-top: 5px;
padding-right: 3px;
padding-bottom: 0px;
#navigation {
clear: both;
float: left;
margin-left: 0;
width: 100%;
display: block;
#exterior_pic {
clear: both;
float: left;
margin-left: 0;
width: 100%;
display: block;
#welcome {
clear: both;
float: left;
margin-left: 0;
width: 100%;
display: block;
#interior_pic {
clear: both;
float: left;
margin-left: 0;
width: 100%;
display: block;
#bottom_nav {
clear: both;
float: left;
margin-left: 0;
width: 100%;
display: block;
#footer {
clear: both;
float: left;
margin-left: 0;
width: 100%;
display: block;
@charset "UTF-8";
/* SpryMenuBarHorizontal.css - version 0.6 - Spry Pre-Release 1.6.1 */
/* Copyright (c) 2006. Adobe Systems Incorporated. All rights reserved. */
LAYOUT INFORMATION: describes box model, positioning, z-order
/* The outermost container of the Menu Bar, an auto width box with no margin or padding */
ul.MenuBarHorizontal
margin: 0;
padding: 0;
list-style-type: none;
font-size: 100%;
cursor: default;
width: auto;
font-family: Georgia, "Times New Roman", Times, serif;
font-weight: bold;
font-style: oblique;
/* Set the active Menu Bar with this class, currently setting z-index to accomodate IE rendering bug: http://therealcrisp.xs4all.nl/meuk/IE-zindexbug.html */
ul.MenuBarActive
z-index: 1000;
/* Menu item containers, position children relative to this container and are a fixed width */
ul.MenuBarHorizontal li
margin: 0;
padding: 0;
font-size: 100%;
position: relative;
text-align: left;
cursor: pointer;
width: 14.28%;
float: left;
/* Submenus should appear below their parent (top: 0) with a higher z-index, but they are initially off the left side of the screen (-1000em) */
ul.MenuBarHorizontal ul
margin: 0;
padding: 0;
font-size: 100%;
z-index: 1020;
cursor: default;
width: 100%;
position: absolute;
left: -1000em;
/* Submenu that is showing with class designation MenuBarSubmenuVisible, we set left to auto so it comes onto the screen below its parent menu item */
ul.MenuBarHorizontal ul.MenuBarSubmenuVisible
left: auto;
/* Menu item containers are same fixed width as parent */
ul.MenuBarHorizontal ul li
float: none;
clear:left;
width: auto;
white-space: nowrap;
/* Submenus should appear slightly overlapping to the right (95%) and up (-5%) */
ul.MenuBarHorizontal ul ul
position: absolute;
margin: -5% 0 0 95%;
/* Submenu that is showing with class designation MenuBarSubmenuVisible, we set left to 0 so it comes onto the screen */
ul.MenuBarHorizontal ul.MenuBarSubmenuVisible ul.MenuBarSubmenuVisible
left: auto;
top: 0;
DESIGN INFORMATION: describes color scheme, borders, fonts
/* Submenu containers have borders on all sides */
border: 1px solid #CCC;
/* Menu items are a light gray block with padding and no text decoration */
ul.MenuBarHorizontal a
display: block;
cursor: pointer;
background-color: #EEE;
padding: 0.5em 0.75em;
color: #333;
text-decoration: none;
border: thick ridge #3b87d5;
/* Menu items that have mouse over or focus have a blue background and white text */
ul.MenuBarHorizontal a:hover, ul.MenuBarHorizontal a:focus
background-color: #33C;
color: #FFF;
/* Menu items that are open with submenus are set to MenuBarItemHover with a blue background and white text */
ul.MenuBarHorizontal a.MenuBarItemHover, ul.MenuBarHorizontal a.MenuBarItemSubmenuHover, ul.MenuBarHorizontal a.MenuBarSubmenuVisible
color: #FFF;
SUBMENU INDICATION: styles if there is a submenu under a given menu item
/* Menu items that have a submenu have the class designation MenuBarItemSubmenu and are set to use a background image positioned on the far left (95%) and centered vertically (50%) */
background-image: url(SpryMenuBarDown.gif);
background-repeat: no-repeat;
background-position: 95% 50%;
ul.MenuBarHorizontal ul a.MenuBarItemSubmenu
background-image: url(SpryMenuBarRight.gif);
/* Menu items that are open with submenus have the class designation MenuBarItemSubmenuHover and are set to use a "hover" background image positioned on the far left (95%) and centered vertically (50%) */
background-image: url(SpryMenuBarDownHover.gif);
ul.MenuBarHorizontal ul a.MenuBarItemSubmenuHover
background-image: url(SpryMenuBarRightHover.gif);
BROWSER HACKS: the hacks below should not be changed unless you are an expert
/* HACK FOR IE: to make sure the sub menus show above form controls, we underlay each submenu with an iframe */
ul.MenuBarHorizontal iframe
position: absolute;
z-index: 1010;
filter:alpha(opacity:0.1);
/* HACK FOR IE: to stabilize appearance of menu items; the slash in float is to keep IE 5.0 from parsing */
@media screen, projection
ul.MenuBarHorizontal li.MenuBarItemIE
display: inline;
f\loat: left;
background: #FFF;
Spry Menus were never designed to work with Fluid Grid layouts. They pre-date them by several years.
As an FYI: Spry framework is no longer being developed by Adobe and is being phased out from future products. So the best advice I can offer you is to find a better menu system, preferably one that is responsive to work with your responsive layouts.
CSS Menu Systems
Nancy O.
As much as I hate to admit it, Nancy is correct.
But being the lover of Spry that I am, have a look at the following.
Change the widths in the following to auto
and add the highlighted to ul.MenuBarHorizontal ul li
width: auto;
display: block;
float: none !important;
width: auto;
North America
Asia Pacific
