adobe4440
need to call servlet  from jsp how
Dec 12, 2012 6:37 AM
generally we specify in action attribute
in cq how to specify the servlet path
what should be the folder structure plz explain with an example
    Dec 12, 2012 9:06 AM   in reply to adobe4440
    http://sling.apache.org/site/servlets.html
    http://wemcode.wemblog.com/create-servlet
    And from JSP just call it using servlet path.
    Yogesh
    www.wemblog.com
    Jan 24, 2013 4:06 AM   in reply to Yogesh Upadhyay
    how to call  can u please tell me need to put the full path of  the sling servlet or to put only the servlet name
  • kasq
    Dec 1, 2011
    Jan 24, 2013 4:18 AM   in reply to ddigal
    hi,
    first of all try to make this kind annotation in your sling servlet:
    @Component(immediate = true, metatype = false, label = "ExampleServlet")
    @Service
    @Properties(value = {
          @org.apache.felix.scr.annotations.Property(name = "sling.servlet.methods", value = { "POST [or GET]" }),
          @org.apache.felix.scr.annotations.Property(name = "sling.servlet.resourceTypes", value = { "sling/servlet/default" }),
          @org.apache.felix.scr.annotations.Property(name = "sling.servlet.selectors", value = { "example" }),
          @org.apache.felix.scr.annotations.Property(name = "sling.servlet.extensions", value = { "html" })
    ......CODE FOR A SERVLET .............
    and then use in your jsp a form like this:
    <form id="submitForm" method="post [or get]" action="test.example.html">
            <input type="submit" value="Submit"/>
      </form>
    Generally speaking your sling servlet is recognize by the selector and extension which is defined in the annotations in the Servlet java file and then using it in the action atribute Sling know which servlet must be called.
    Of course before you start testing you servlet, the bundle with your servlet must be installed and active in the Apache Felix Console and also your ExampleServlet must be visible in the bundle in the Services list.
    Regards,
    kasq
    Jan 24, 2013 4:32 AM   in reply to kasq
    thanks kasq for giving me the fully knowledge on slingservlet
    Regards
    ddigal
    Feb 4, 2013 11:02 PM   in reply to kasq
    when i put this notation  its showing type property is ambiguous.what to do pls tell dude
    Jun 28, 2013 11:10 AM   in reply to adobe4440
Bookmarked By (1)
