CSS height property use in Fluid grid layout
Dec 12, 2012 9:16 AM
Hi, I'm totally new to fluid grid layout and just got started in it. I have a div tag that has 5px height and I sucessfully applied that and seem fine only on Tablet landscape (1024x768) and Small tablet landscape (800x600), nevertheless it isn't even displaying on Mobile portrait (320x480), Mobile landscape (480x320), Small tablet portrait (600x800) and Tablet portrait (768x1024).
My coding is below
index.html
<!doctype html>
<!--[if lt IE 7]> <html class="ie6 oldie"> <![endif]-->
<!--[if IE 7]>    <html class="ie7 oldie"> <![endif]-->
<!--[if IE 8]>    <html class="ie8 oldie"> <![endif]-->
<!--[if gt IE 8]><!-->
<html class="">
<!--<![endif]-->
<head>
<meta charset="utf-8">
<meta name="viewport" content="width=device-width, initial-scale=1">
<title>Untitled Document</title>
<link href="fluid.grid.layout/boilerplate.css" rel="stylesheet" type="text/css">
<link href="fluid.grid.layout/style.css" rel="stylesheet" type="text/css">
To learn more about the conditional comments around the html tags at the top of the file:
paulirish.com/2008/conditional-stylesheets-vs-css-hacks-answer-neither/
Do the following if you're using your customized build of modernizr (http://www.modernizr.com/):
* insert the link to your js here
* remove the link below to the html5shiv
* add the "no-js" class to the html tags at the top
* you can also remove the link to respond.min.js if you included the MQ Polyfill in your modernizr build
<!--[if lt IE 9]>
<script src="//html5shiv.googlecode.com/svn/trunk/html5.js"></script>
<![endif]-->
<script src="fluid.grid.layout/respond.min.js"></script>
</head>
<body>
<div class="gridContainer clearfix">
  <div id="LayoutDiv1"></div>
</div>
</body>
</html>
boilerplate.css
@charset "utf-8";
 * HTML5 ✰ Boilerplate
 * What follows is the result of much research on cross-browser styling.
 * Credit left inline and big thanks to Nicolas Gallagher, Jonathan Neal,
 * Kroc Camen, and the H5BP dev community and team.
 * Detailed information about this CSS: h5bp.com/css
 * Dreamweaver modifications:
 * 1. Commented out selection highlight
 * 2. Removed media queries section (we add our own in a separate file)
 * ==|== normalize ==========================================================
   HTML5 display definitions
article, aside, details, figcaption, figure, footer, header, hgroup, nav, section { display: block; }
audio, canvas, video { display: inline-block; *display: inline; *zoom: 1; }
audio:not([controls]) { display: none; }
[hidden] { display: none; }
   Base
 * 1. Correct text resizing oddly in IE6/7 when body font-size is set using em units
 * 2. Force vertical scrollbar in non-IE
 * 3. Prevent iOS text size adjust on device orientation change, without disabling user zoom: h5bp.com/g
html { font-size: 100%; overflow-y: scroll; -webkit-text-size-adjust: 100%; -ms-text-size-adjust: 100%; }
body { margin: 0; font-size: 13px; line-height: 1.231; }
body, button, input, select, textarea { font-family: sans-serif; color: #222; }
 * Remove text-shadow in selection highlight: h5bp.com/i
 * These selection declarations have to be separate
 * Also: hot pink! (or customize the background color to match your design)
/* Dreamweaver: uncomment these if you do want to customize the selection highlight
 *::-moz-selection { background: #fe57a1; color: #fff; text-shadow: none; }
 *::selection { background: #fe57a1; color: #fff; text-shadow: none; }
   Links
a { color: #00e; }
a:visited { color: #551a8b; }
a:hover { color: #06e; }
a:focus { outline: thin dotted; }
/* Improve readability when focused and hovered in all browsers: h5bp.com/h */
a:hover, a:active { outline: 0; }
   Typography
abbr[title] { border-bottom: 1px dotted; }
b, strong { font-weight: bold; }
blockquote { margin: 1em 40px; }
dfn { font-style: italic; }
hr { display: block; height: 1px; border: 0; border-top: 1px solid #ccc; margin: 1em 0; padding: 0; }
ins { background: #ff9; color: #000; text-decoration: none; }
mark { background: #ff0; color: #000; font-style: italic; font-weight: bold; }
/* Redeclare monospace font family: h5bp.com/j */
pre, code, kbd, samp { font-family: monospace, monospace; _font-family: 'courier new', monospace; font-size: 1em; }
/* Improve readability of pre-formatted text in all browsers */
pre { white-space: pre; white-space: pre-wrap; word-wrap: break-word; }
q { quotes: none; }
q:before, q:after { content: ""; content: none; }
small { font-size: 85%; }
/* Position subscript and superscript content without affecting line-height: h5bp.com/k */
sub, sup { font-size: 75%; line-height: 0; position: relative; vertical-align: baseline; }
sup { top: -0.5em; }
sub { bottom: -0.25em; }
   Lists
ul, ol { margin: 1em 0; padding: 0 0 0 40px; }
dd { margin: 0 0 0 40px; }
nav ul, nav ol { list-style: none; list-style-image: none; margin: 0; padding: 0; }
   Embedded content
 * 1. Improve image quality when scaled in IE7: h5bp.com/d
 * 2. Remove the gap between images and borders on image containers: h5bp.com/e
img { border: 0; -ms-interpolation-mode: bicubic; vertical-align: middle; }
 * Correct overflow not hidden in IE9
svg:not(:root) { overflow: hidden; }
   Figures
figure { margin: 0; }
   Forms
form { margin: 0; }
fieldset { border: 0; margin: 0; padding: 0; }
/* Indicate that 'label' will shift focus to the associated form element */
label { cursor: pointer; }
 * 1. Correct color not inheriting in IE6/7/8/9
 * 2. Correct alignment displayed oddly in IE6/7
legend { border: 0; *margin-left: -7px; padding: 0; }
 * 1. Correct font-size not inheriting in all browsers
 * 2. Remove margins in FF3/4 S5 Chrome
 * 3. Define consistent vertical alignment display in all browsers
button, input, select, textarea { font-size: 100%; margin: 0; vertical-align: baseline; *vertical-align: middle; }
 * 1. Define line-height as normal to match FF3/4 (set using !important in the UA stylesheet)
 * 2. Correct inner spacing displayed oddly in IE6/7
button, input { line-height: normal; *overflow: visible; }
 * Reintroduce inner spacing in 'table' to avoid overlap and whitespace issues in IE6/7
table button, table input { *overflow: auto; }
 * 1. Display hand cursor for clickable form elements
 * 2. Allow styling of clickable form elements in iOS
button, input[type="button"], input[type="reset"], input[type="submit"] { cursor: pointer; -webkit-appearance: button; }
 * Consistent box sizing and appearance
input[type="checkbox"], input[type="radio"] { box-sizing: border-box; }
input[type="search"] { -webkit-appearance: textfield; -moz-box-sizing: content-box; -webkit-box-sizing: content-box; box-sizing: content-box; }
input[type="search"]::-webkit-search-decoration { -webkit-appearance: none; }
 * Remove inner padding and border in FF3/4: h5bp.com/l
button::-moz-focus-inner, input::-moz-focus-inner { border: 0; padding: 0; }
 * 1. Remove default vertical scrollbar in IE6/7/8/9
 * 2. Allow only vertical resizing
textarea { overflow: auto; vertical-align: top; resize: vertical; }
/* Colors for form validity */
input:valid, textarea:valid {  }
input:invalid, textarea:invalid { background-color: #f0dddd; }
   Tables
table { border-collapse: collapse; border-spacing: 0; }
td { vertical-align: top; }
/* ==|== primary styles =====================================================
   Author:
/* ==|== non-semantic helper classes ========================================
   Please define your styles before this section.
/* For image replacement */
.ir { display: block; border: 0; text-indent: -999em; overflow: hidden; background-color: transparent; background-repeat: no-repeat; text-align: left; direction: ltr; }
.ir br { display: none; }
/* Hide from both screenreaders and browsers: h5bp.com/u */
.hidden { display: none !important; visibility: hidden; }
/* Hide only visually, but have it available for screenreaders: h5bp.com/v */
.visuallyhidden { border: 0; clip: rect(0 0 0 0); height: 1px; margin: -1px; overflow: hidden; padding: 0; position: absolute; width: 1px; }
/* Extends the .visuallyhidden class to allow the element to be focusable when navigated to via the keyboard: h5bp.com/p */
.visuallyhidden.focusable:active, .visuallyhidden.focusable:focus { clip: auto; height: auto; margin: 0; overflow: visible; position: static; width: auto; }
/* Hide visually and from screenreaders, but maintain layout */
.invisible { visibility: hidden; }
/* Contain floats: h5bp.com/q */
.clearfix:before, .clearfix:after { content: ""; display: table; }
.clearfix:after { clear: both; }
.clearfix { zoom: 1; }
/* ==|== print styles =======================================================
   Print styles.
   Inlined to avoid required HTTP connection: h5bp.com/r
 @media print {
  * { background: transparent !important; color: black !important; text-shadow: none !important; filter:none !important; -ms-filter: none !important; } /* Black prints faster: h5bp.com/s */
  a, a:visited { text-decoration: underline; }
  a[href]:after { content: " (" attr(href) ")"; }
  abbr[title]:after { content: " (" attr(title) ")"; }
  .ir a:after, a[href^="javascript:"]:after, a[href^="#"]:after { content: ""; }  /* Don't show links for images, or javascript/internal links */
  pre, blockquote { border: 1px solid #999; page-break-inside: avoid; }
  thead { display: table-header-group; } /* h5bp.com/t */
  tr, img { page-break-inside: avoid; }
  img { max-width: 100% !important; }
  @page { margin: 0.5cm; }
  p, h2, h3 { orphans: 3; widows: 3; }
  h2, h3 { page-break-after: avoid; }
style.css
@charset "utf-8";
/* Simple fluid media
   Note: Fluid media requires that you remove the media's height and width attributes from the HTML
   http://www.alistapart.com/articles/fluid-images/
img, object, embed, video {
          max-width: 100%;
/* IE 6 does not support max-width so default to width 100% */
.ie6 img {
          width:100%;
          Dreamweaver Fluid Grid Properties
          dw-num-cols-mobile:                    4;
          dw-num-cols-tablet:                    8;
          dw-num-cols-desktop:          10;
          dw-gutter-percentage:          25;
          Inspiration from "Responsive Web Design" by Ethan Marcotte
          http://www.alistapart.com/articles/responsive-web-design
          and Golden Grid System by Joni Korpi
          http://goldengridsystem.com/
/* Mobile Layout: 480px and below. */
.gridContainer {
          margin-left: auto;
          margin-right: auto;
          width: 85.5%;
          padding-left: 2.25%;
          padding-right: 2.25%;
#LayoutDiv1 {
          clear: both;
          float: left;
          margin-left: 0;
          width: 100%;
          height:5px;
          display: block;
/* Tablet Layout: 481px to 768px. Inherits styles from: Mobile Layout. */
@media only screen and (min-width: 481px) {
.gridContainer {
          width: 97.5%;
          padding-left: 1.25%;
          padding-right: 1.25%;
#LayoutDiv1 {
          clear: both;
          float: left;
          margin-left: 0;
          width: 100%;
          height:5px;
          display: block;
/* Desktop Layout: 769px to a max of 1232px.  Inherits styles from: Mobile Layout and Tablet Layout. */
@media only screen and (min-width: 769px) {
.gridContainer {
          width: 98%;
          max-width: 1232px;
          padding-left: 1%;
          padding-right: 1%;
          margin: auto;
#LayoutDiv1 {
          clear: both;
          float: left;
          margin-left: 0;
          width: 100%;
          display: block;
          height:5px;
          background-color:#FBB829;
respond.min.js
/*! Respond.js v1.0.1pre: min/max-width media query polyfill. (c) Scott Jehl. MIT/GPLv2 Lic. j.mp/respondjs  */
(function(e,h){e.respond={};respond.update=function(){};respond.mediaQueriesSupported=h;if(h){return}var u=e.document,r=u.documentElement,i=[],k=[],p=[],o={},g=30,f=u.getElementsByTagName("head")[0]||r,b=f.getElementsByTagName("link"),d=[],a=function(){var B=b,w=B.length,z=0,y,x,A,v;for(;z<w;z++){y=B[z],x=y.href,A=y.media,v=y.rel&&y.rel.toLowerCase()==="stylesheet";if(!!x&&v&&!o[x]){if(y.styleSheet&&y.styleSheet.rawCssText){m(y.styleSheet.rawCssText,x,A);o[x]=true}else{if(!/^([a-zA-Z]+?:(\/\/)?)/.test(x)||x.replace(RegExp.$1,"").split("/")[0]===e.location.host){d.push({href:x,media:A})}}}}t()},t=function(){if(d.length){var v=d.shift();n(v.href,function(w){m(w,v.href,v.media);o[v.href]=true;t()})}},m=function(G,v,x){var E=G.match(/@media[^\{]+\{([^\{\}]+\{[^\}\{]+\})+/gi),H=E&&E.length||0,v=v.substring(0,v.lastIndexOf("/")),w=function(I){return I.replace(/(url\()['"]?([^\/\)'"][^:\)'"]+)['"]?(\))/g,"$1"+v+"$2$3")},y=!H&&x,B=0,A,C,D,z,F;if(v.length){v+="/"}if(y){H=1}for(;B<H;B++){A=0;if(y){C=x;k.push(w(G))}else{C=E[B].match(/@media ([^\{]+)\{([\S\s]+?)$/)&&RegExp.$1;k.push(RegExp.$2&&w(RegExp.$2))}z=C.split(",");F=z.length;for(;A<F;A++){D=z[A];i.push({media:D.match(/(only\s+)?([a-zA-Z]+)(\sand)?/)&&RegExp.$2,rules:k.length-1,minw:D.match(/\(min\-width:[\s]*([\s]*[0-9]+)px[\s]*\)/)&&parseFloat(RegExp.$1),maxw:D.match(/\(max\-width:[\s]*([\s]*[0-9]+)px[\s]*\)/)&&parseFloat(RegExp.$1)})}}j()},l,q,j=function(E){var v="clientWidth",x=r[v],D=u.compatMode==="CSS1Compat"&&x||u.body[v]||x,z={},C=u.createDocumentFragment(),B=b[b.length-1],w=(new Date()).getTime();if(E&&l&&w-l<g){clearTimeout(q);q=setTimeout(j,g);return}else{l=w}for(var y in i){var F=i[y];if(!F.minw&&!F.maxw||(!F.minw||F.minw&&D>=F.minw)&&(!F.maxw||F.maxw&&D<=F.maxw)){if(!z[F.media]){z[F.media]=[]}z[F.media].push(k[F.rules])}}for(var y in p){if(p[y]&&p[y].parentNode===f){f.removeChild(p[y])}}for(var y in z){var G=u.createElement("style"),A=z[y].join("\n");G.type="text/css";G.media=y;if(G.styleSheet){G.styleSheet.cssText=A}else{G.appendChild(u.createTextNode(A))}C.appendChild(G);p.push(G)}f.insertBefore(C,B.nextSibling)},n=function(v,x){var w=c();if(!w){return}w.open("GET",v,true);w.onreadystatechange=function(){if(w.readyState!=4||w.status!=200&&w.status!=304){return}x(w.responseText)};if(w.readyState==4){return}w.send(null)},c=(function(){var v=false;try{v=new XMLHttpRequest()}catch(w){v=new ActiveXObject("Microsoft.XMLHTTP")}return function(){return v}})();a();respond.update=a;function s(){j(true)}if(e.addEventListener){e.addEventListener("resize",s,false)}else{if(e.attachEvent){e.attachEvent("onresize",s)}}})(this,(function(f){if(f.matchMedia){return true}var e,i=document,c=i.documentElement,g=c.firstElementChild||c.firstChild,h=!i.body,d=i.body||i.createElement("body"),b=i.createElement("div"),a="only all";b.id="mq-test-1";b.style.cssText="position:absolute;top:-99em";d.appendChild(b);b.innerHTML='_<style media="'+a+'"> #mq-test-1 { width: 9px; }</style>';if(h){c.insertBefore(d,g)}b.removeChild(b.firstChild);e=b.offsetWidth==9;if(h){c.removeChild(d)}else{d.removeChild(b)}return e})(this));
I really do appreciate your efforts to help me solve this problem... Thank you in advance
    Dec 12, 2012 10:31 AM   in reply to xhpx
    Height is determined by content.  I can't think of a single reason to have a div height of 5px because almost nothing will fit inside that small a space without problems.
    As to why it doesn't show up in other devices, you must have put that style into the Tablet CSS code instead of the default Mobile CSS code.
    Fluid Grids build up from Mobile (applied to everything) with specific rules for Tablets, then Desktops.
    Best advice, use Fluid Grids for layout only.  Use a separate CSS file for content styles.
    Hope this helps,
    Nancy O.
