Question about states
Dec 12, 2012 2:26 PM
Hi All,
I have a flex app using two states:
<s:states>
        <s:State name="Dashboard"/>
        <s:State name="Login"/>
</s:states>
This app shows the login state in a corner of an ASP.net app with small width.
<s:BorderContainer includeIn="Login" cornerRadius="0" width="253" height="400" backgroundImage="{imgCls}" >
After the user pass login the app change to the Dashboard state but still show the app in the small corner of the ASP.net app.
<s:BorderContainer cornerRadius="0" width="100%" height="100%" includeIn="Dashboard">
How can I take over the whole screen of the browser after user pass the login?
Thanks in advance.
Best,
    Dec 15, 2012 12:33 PM   in reply to jfb00
    If I understand the question; you want the app one size upon load; but you want to make it bigger after they login.
    A Flash app is, basically, just a square set up in the browser.  Flex / Flash has no control over that square and cannot change it.
    You may be able to work something up using ExternalInterface to run a JavaScript method to change the dimensions of the Flex app.
    Yes, popping open a windw or opening a new URL will always reload a Flex page; and that usually means resetting the app to the default state; which in this case is not logged in.
