JeffKa123
Audio- & Videolength Importing Issue
Dec 13, 2012 10:24 AM
When i'm importing audio(wave) & videofiles (mp4) in Premiere Pro CS6, the files appear much shorter than they originally are.
For example: My audiofile is 5seconds long, but when i import it i can only see/hear about a half second of it.
How can i fix this?
    Dec 13, 2012 1:21 PM   in reply to JeffKa123
    Does the whole clip show up in the Source Monitor?
    Dec 13, 2012 4:46 PM   in reply to JeffKa123
    For the Audio, when Imported, did you let Conforming complete 100%?
    Does the Waveform Display of the WAV file, show "flatline," at the point of truncation?
    Dec 14, 2012 7:13 AM   in reply to JeffKa123
    With such a short WAV file, the Conforming process, even if one only has a moderately fast system, is probably done so quickly, that one never sees the progress bar - it just never has time to display, and probably did complete 100%. It sounds like you did get the full PEK file (Audio Waveform Display), which is part of the Conforming process.
    Not sure what is happening in your case, and I think that we can safely rule out the Conforming process. Thanks for the info.
    Wish that I had some other thoughts, but maybe others will.
    Dec 14, 2012 8:26 AM   in reply to JeffKa123
    OK.
    Open the .wav in Audition, what does it show?
