CarolinaTigerRescue
form validation of text fields and checkbox
Dec 13, 2012 12:11 PM
Tags: #form #validation #checkbox
I have Dreamweaver CS3.  My form includes several field validations on text boxes and I was able to use a behavior on the form tag to validate my text fields, but I also have a Terms and Conditions checkbox that I need to validate as Checked.  Everything I have found online suggests using a spry checkbox to validate, but this seems to conflict with the code that is validating the text fields.
How can I validate my checkbox as well?
Code:
(in header)
function MM_validateForm() { //v4.0
  if (document.getElementById){
    var i,p,q,nm,test,num,min,max,errors='',args=MM_validateForm.arguments;
    for (i=0; i<(args.length-2); i+=3) { test=args[i+2]; val=document.getElementById(args[i]);
      if (val) { nm=val.name; if ((val=val.value)!="") {
        if (test.indexOf('isEmail')!=-1) { p=val.indexOf('@');
          if (p<1 || p==(val.length-1)) errors+='- '+nm+' must contain an e-mail address.\n';
        } else if (test!='R') { num = parseFloat(val);
          if (isNaN(val)) errors+='- '+nm+' must contain a number.\n';
          if (test.indexOf('inRange') != -1) { p=test.indexOf(':');
            min=test.substring(8,p); max=test.substring(p+1);
            if (num<min || max<num) errors+='- '+nm+' must contain a number between '+min+' and '+max+'.\n';
      } } } else if (test.charAt(0) == 'R') errors += '- '+nm+' is required.\n'; }
    } if (errors) alert('The following error(s) occurred:\n'+errors);
    document.MM_returnValue = (errors == '');
(in body)
<form action="https://faas.cloud.clickandpledge.com" method="post" id="Donation" onsubmit="MM_validateForm('NameOnCard','','R','CardNumber','','R','Cv v2','','R','BillingFirstName','','R','BillingLastName','','R','Billing Phone','','R','BillingEmail','','RisEmail','BillingAddress1','','R','B illingCity','','R','BillingPostalCode','','R');return document.MM_returnValue">
(checkbox that needs validation)
<input name="Terms" type="checkbox" />
gratefully, Amanda
    Dec 13, 2012 12:28 PM   in reply to CarolinaTigerRescue
    Personally, I'm not a fan of DW's built in JavaScript.  Better to learn JavaScript and write your own.  Even better to use server-side validation.
    Just my $0.02 worth.
    ^_^
    Dec 13, 2012 4:30 PM   in reply to CarolinaTigerRescue
    I agree with WolfShade.
    Client side validation will fail if JavaScript is disabled.  A lot of people disable JS for perceived browser security reasons.  Firefox even has an Add-on for this called NoScripts.
    Server-side validation contained inside your form processing script is the safer & more reliable way to go.
    Nancy O.
