FB 4.5 crash in windows 7 after today update
Dec 13, 2012 3:08 PM
Hi all,
After updating windows 7 update my FB 4.6 stop working. I found this error on a log file:
# A fatal error has been detected by the Java Runtime Environment:
#  EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x0018e24e, pid=4624, tid=1336
# JRE version: 6.0_16-b01
# Java VM: Java HotSpot(TM) Client VM (14.2-b01 mixed mode windows-x86 )
# Problematic frame:
# C  0x0018e24e
# If you would like to submit a bug report, please visit:
#   http://java.sun.com/webapps/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
I reinstall the FB but no luck, this is very frustrating.
Anyone knows how to fix this?
    Dec 17, 2012 2:42 PM   in reply to jfb00
    Title & post mention different versions, 4.5 or 4.6?
    Suggestions:
    -Try re-installing to the most recent version of Java - also might want to play with 32 bit vs 64 bit Java installs
    -Usually such errors make this kind of a thing a bit more obvious, but you could try messing with increasing the memory available to the jvm running FB. I believe modifying the -X values in FlashBuilder.ini should do this.  I had to do this once (who knows what they did to our workstations to require it), but like I said usually there's a more obvious error message...
