HTML not exporting correctly
Dec 19, 2012 8:46 AM
Tags: #html #cs5.5 #swf #flash_cs6
I can export HTML fine from my machine using CS6. However, the same file exported on two different machines one with cs6 and one with cs5.5. We can't seem to get my colleagues HTML file to run in a browser. This one is in AS2, all settings for publishing generally look the same, but my knowledge of flash is limited. If anyone could help, that would be great.
My HTML is as follows...
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" lang="en" xml:lang="en">
          <head>
                    <title>Special Cases for a Risk Assessment</title>
                    <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
                    <style type="text/css" media="screen">
                    html, body { height:100%; background-color: #ffffff;}
                    body { margin:0; padding:0; overflow:hidden; }
                    #flashContent { width:100%; height:100%; }
                    </style>
          </head>
          <body>
                    <div id="flashContent">
                              <object classid="clsid:d27cdb6e-ae6d-11cf-96b8-444553540000" width="710" height="600" id="Special Cases for a Risk Assessment" align="middle">
                                        <param name="movie" value="Special Cases for a Risk Assessment.swf" />
                                        <param name="quality" value="high" />
                                        <param name="bgcolor" value="#ffffff" />
                                        <param name="play" value="true" />
                                        <param name="loop" value="true" />
                                        <param name="wmode" value="transparent" />
                                        <param name="scale" value="showall" />
                                        <param name="menu" value="true" />
                                        <param name="devicefont" value="false" />
                                        <param name="salign" value="" />
                                        <param name="allowScriptAccess" value="sameDomain" />
                                        <!--[if !IE]>-->
                                        <object type="application/x-shockwave-flash" data="Special Cases for a Risk Assessment.swf" width="710" height="600">
                                        <!--<![endif]-->
                                                  <a href="http://www.adobe.com/go/getflash">
                                                            <img src="http://www.adobe.com/images/shared/download_buttons/get_flash_player.g if" alt="Get Adobe Flash player" />
                                                  </a>
                                        <!--[if !IE]>-->
                                        </object>
                                        <!--<![endif]-->
                              </object>
                    </div>
          </body>
</html>
The other HTML is....
<html lang="en">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=us-ascii">
html, body
          {height:100%;
          background-color:#ffffff}
body
          {margin:0;
          padding:0;
          overflow:hidden}
#flashContent
          {width:100%;
          height:100%}
</style>
</head>
<body>
<div id="flashContent"><a href="redir.aspx?C=2e9d6631ce744b66830cc980c35dd9d7&amp;URL=http%3a%2 f%2fwww.adobe.com%2fgo%2fgetflash" target="_blank"><img src="8.1.436.0/themes/base/clear.gif" alt="Get Adobe Flash player">
</a></div>
</body>
</html>
Louise
  • kglad
    Jul 21, 2002
    Dec 19, 2012 9:14 AM   in reply to LouiseCox
    that "other html" is missing the flash embedding code.
    whoever is publishing that needs to fix their flash pro publishing template.  what os is that person using and are they using flash pro cs6?
