david.r.bell
installing FM8 on windows 8- how to deal with a 1603 error ?
Dec 19, 2012 4:51 PM
Hi all
i have run FM8 on Windows 7 for a long time, but upgraded to Win 8.
I have installed CS4, but now that I am attempting to install FM8, i have a problem. The install goes almost all the way to the end; the installer mentions something about updating registry entries, but this goes by in a flash. Then the install rolls everything back. It says there is a 1603 error.
Win compatibility modes don't seem to help, nor does installing from hard disk. I have switched off all the startup items, changed permissions on spool/drivers, but i still get the same error.
can anyone help ?
many thanks in advance
david
    Dec 19, 2012 6:16 PM   in reply to david.r.bell
    I don't know if this will help with Windows 8 installations, but XP
    service pack 3 broke the installation of FM8 from disk. Adobe issued a
    new installer online, but you have to download it. I believe this
    installer was also necessary for later Windows versions. Anyway, worth a
    try.
    You can download the fixed installer here:
    http://www.adobe.com/support/downloads/detail.jsp?ftpID=4549
    Dec 20, 2012 6:08 AM   in reply to david.r.bell
    Install it in a virtual XP drive?
    PS – why are you using FM8 when FM11 is out there now?
    Dec 20, 2012 1:40 PM   in reply to david.r.bell
    Going the virtual route may be your only choice to getting FM8 installed on your Win8 machine. You do have full admin rights to your drive, right?
    Dec 20, 2012 2:07 PM   in reply to david.r.bell
    Have you contacted Adobe Support? Usually install issues are freebies.
    Dec 20, 2012 3:38 PM   in reply to Jeff_Coatsworth
    Freebie support is typically for current products and you must meet all of the listed specifications for your installation machine. Since FM8 was developed way before Win8 (and even Win7), it's highly unlikely that they'll provide any support for a release three versions back from the current one.
    As has been mentioned, your best bet may be creating a virtual XP machine and installing FM8 on that if running your setup in compatibility mode didn't do it for you..
    You also might want to have look at this message/thread that threw the same error:
    http://forums.adobe.com/message/4377543#4377543
    Dec 21, 2012 5:32 AM   in reply to david.r.bell
    Its not compatible as its not been tested on Win 8 and its an old version
    Even Framemaker 11 system requirement is only till Win 7.
    Harpreet
