Hello
My problem is that when I import AVI files into Encore, it's only sound that comes with - The video track is empty.
If I play the same movie with Media Player does is both play sound and picture.
What am I doing wrong?
The first DVD I made, I could well do in Encore, but when I played it on my DVD player flickering image. - What should I change to fix this problem ?
I can see the "Quality settings" the source is 720x480 29,97 fps, but the AVI i'm importing is 720x576 25 fps ?
I don't think Encore is the right place to try and convert NTSC to PAL
Convert NTSC <--> PAL http://forums.adobe.com/thread/995779
Ok - I have imported from the camera to AVS Video editor via USB, then Adobe Promiere can't capture via USB, but need a FireWire connection, (1394) mabye I shall buy a FireWire adapter sow I can capture direct to Premiere -
is there one of you who can recommend FireWire adapter (1394) that I use with Premiere and my analog camcorder?
If you really have an ANALOG camcorder, not a DIGITAL camcorder... it will not work with Firewire, since the analog signal must be converted to digital
I am confused, so please post the brand & model camera you have... and maybe a web link to the vendor page so people may determine if you really have an analog or a digital camcorder
Oh Dear - AVS uses a library called ffmpeg, which is largely based on reverse engineered commercial codecs and is not - ever - guaranteed to be DVD compliant in it's output.
What looks like has happened to me is that the encore project appears to be NTSC (720x480) and I suspect the flickering issues are caused by changing frame rates in that dodgy conversion utility.
Can you please confirm the following:
1 - Project settings in Encore
2 - Camera settings
3 - Settings used in AVS - including codec used?
Analogue to digital via FireWire capture can be done if you have a special box to do this.
North America
Asia Pacific
