Howard Sampson
photoshop 9 and windows 8
Dec 25, 2012 4:38 PM
Tags: #elements9 #-windows8-
i installed photoshop elements 9 in windows 8 64 bit the organizer will open but the edit will not respond  does anyony have a solution ??
    Dec 26, 2012 11:39 AM   in reply to Howard Sampson
    Moving this discussion to the Photoshop Elements forum.
    Jan 3, 2013 3:19 AM   in reply to Jeff A Wright
    Win 8 has been released now and PSE9 came way back in 2010, so it might be possible that one or the other components is changed or not there in WIn 8 or PSE 9 Editor might not work.
    Please try couple of probable solutions as mentioned below:
    Solution 1:
    1. Close Elements.
    2. Launch the Photoshop Elements Welcome Screen and hold down ctrl + alt + shift as you click Editor.
    3. Continue to hold the keys until you see a message box asking if you want to delete Photoshop Elements settings file; click Yes. Elements will open with default preferences.
    Solution 2: In case any network printer is attached try to launch without network or printer uninstall or make different printer as default.
    Solution 3: Try launching with anti-virus off or removing PSE from conflicting list.
    Garry
    Jan 22, 2013 9:17 PM   in reply to Howard Sampson
    Can you please share the steps from start to the step where you face the issue?
    Some more troubleshooting steps are :
    1) Turn anti-virus and try using OR
    2) Run as administrator OR
    3) Create new admin user and try
    4) If still not working Share your system info from Help->System Info
    Garry
    Jan 24, 2013 12:38 PM   in reply to Howard Sampson
    What happens when you launch Editor from
    C:\Program Files (x86)\Adobe\Photoshop Elements 11\PhotoshopElementsEditor
    Does it show anything? Or does it crash?
    Check in the task manager as well, in the processes tab, if it launches Editor as a background process or not? The name of the process should be PhotoshopElementsEditor.exe
