MERRY CHRISTMAS AND A HAPPY NEW YEAR!![]()
I have very poor video quality after transcoding the video file (MPEG) in Adobe Encore CS5.1. Below you see my used settings in my filmproject.
The problem exists after transcoding in Adobe Encore CS5.1. I checked all steps and found out that there is no problem until transcoding. My exported file in MPEG has very good video and audio quality.
Facts:
1. Camcorder: Panasonic AG-AC160AEJ
Operating System : Windows 7, 64 Bit, Ultimate edition
Source files: MTS files
Recording settings (clip settings):
Type: MPEG Movie
Image Size: 1920 x 1080
Frame Rate: 25,00
Source Audio Format: 48000 Hz - compressed - Stereo
Project Audio Format: 48000 Hz - 32 bit floating point - Stereo
Pixel Aspect Ratio: 1,0
2. Sequence settings in Premiere Pro
Sequence was created from Clip directly with settings above.
3. Exporting settings in Adobe Premiere Pro:
Match sequence settings was activated. Now other changes were set.
4. Exported File:
Video
Data Transfer Rate: 25920 kBit / s
Frame rate: 25
Audio:
Bit rate: 384 kBit / s
Channels: 2 (stereo)
Frequence: 48 kHz
5. Transcoding settings in Adobe Encore:
I used different transcoding settings such as automatic DVD Transcoding, CBR and VBR.I also set “use maximum render quality”. But all results were always the same: very poor quality.
Why does the encore transcoding cause such bad video quality?
How can I solve this problem?![]()
Please help me soon.
Best regards.
Dear Ann,
I tried many options, including MPEG2-DVD with multiplexer off, in PremierePro in exporting settings. The exported file in your suggestion has poor video quality although the preset setting has highest quality.
I tried also H.264 and other export settings. The results were the same.
When I used "Match sequence settings" in the exporting settings in Premiere Pro, I got as result the xxxx.MPEG file with excellent quality.
BUT after the transcoding the xxxx.MPEG file in Encore, the viedo quality is absolutely poor!
The simple and free DVD authoring tools such as "DVDStyler" or "DVD Flick" have the better results than Adobe Encore!!!
It must be a reason for it. As I read in forums, many people claim about the quality in Encore.
Who can give me other tipps or a solution for this big problem?
Regards
If I understand your examples, you are exporting high def files from Premiere and then comparing them to Encore files after it downrezzing them to DVD size. Ann's suggestion is to export/transcode once, from Premeire, so that the file says "do not transcode" once in an Encore DVD project. Is that what you tried? How does the DVD-pixel-size MPEG2 look from Premiere?
Hi Stan,
yes, I did not transcode the exported MPEG2-DVD file in Encore, as you know, it does not need to be transoced in Encore again. The problem is that the exported MPEG2-DVD file has the poor quality.
Here are the settings in exporting process in Premiere Pro:
Format: MPEG2-DVD
Preset: Match Source Attributes (Highest Quality)
Source: xxxx.MTS, 1920 x 1080 (1,0), 25 fps
Output: PAL, 720 x 576, 25 fps
Regards
In my post 3, I was responding this;
In your post 4, you indicate that you are now exporting a file from premiere that does not look good.
Export a short, representative piece and post where we can download and take a look.
Hi Stan,
I exported now a short clip (about 42 seconds) by using following exporting settings in Premiere Pro:
Format: MPEG2-DVD
Preset: Match source attributes (highest quality)
Codec: MainConcept MPEG Video
Frame Rate: Automatic (based on source)
Field Order: Automatic (based on source)
Pixel Aspect Ratio: Automatic (based on source)
Bitrate Encoding: VBR, 2 Pass
Multiplexer: None
Result: poor video
You can download the video and audio files by following links:
http://www.klavierlehrer-bayern.de/download/test_short_mpeg2_DVD.m2v
http://www.klavierlehrer-bayern.de/download/test_short_mpeg2_DVD.wav
When I export the same clip by using the option "Match sequent settings", then I get very good quality. But the problem, if I use this file in Encore, after transcoding is the video quality again very poor!
Regards
Your example is not bad considering its HD to SD. You could tweak the bitrate.
Don't use match sequence settings.
Use a preset (like NTSC widescreen high quality) or set everything manually.
Or use Dynamic Link and let Encore do the math.
If you want better quality use avisynth + HC encoder or frameserving +TMPGenc.
Listen to Ann.
Note that of the settings you are giving us, you are not reporting the bitrate. The "highest quality" is a preset name; it does not mean taht you cannot tweak the bitrate and get better quality. Edit: the default for that setting is an average target of 6, max of 7. Many users push those.
When you play this back and see it as poor quality, what player are you using and are you making sure it is not zoomed? (Make sure the computer window it is playing in is not full screen, but 720x576.
Note that you have the think black lines left and right. Set output crop to "scale to fill."
Hi Ann,
1) I did not only „Automatic (based on source)“ options in my tests, but also many other customized options.
The results are very poor. I have done a new test with the following settings. The result is also poor:
Download link: http://www.klavierlehrer-bayern.de/download/test_mpeg2dvd_1.m2v
Export Settings:
Format: MPEG2-DVD
Preset: Custom
Codec: MainConcept MPEG Video, Quality: 5
Frame Rate: 25 fps
Field Order: Upper
Render at Maximum Rate: [active]
Bitrate Encoding: VBR, 2 pass
Minimum Bitrate (Mbps): 5
Target Bitrate (Mbps): 9
Maximum Bitrate (Mbps): 9
GOP Settings
M Frames: 4
N Frames: 12
Use Maximum Render Quality: [active]
Multiplexer: None
2) Why shouldn’t I use the “Match Sequence Settings” in exporting? Because of the big output file size?
I used it and the results are very good as I expected:
Download link: http://www.klavierlehrer-bayern.de/download/test_MatchSequenceSettings .mpeg
Export Settings
Match Sequence Settings [selected]
1920 x 1080, 25 fps, Upper, Quality 50
User Maximum Render Quality: [active]
3) I tried also Dynamic Link in PremierePro (to Encore).
The results are also poor.
4) I will test also LagarithLoslessCodec and frameserving +DGMPGDec. But the video is vertical long drawn-ot.
I think I did not use it correctly.
Regards
Hi Stan,
I use Philips 46PFL8606K to see the results. The automatic zoom is disabled.
My source file has 1920 x 1080i, 25 fps, PAR 1,0. I use PAL standard in DVD creating because of compatibility in Europe.
Regards
How are you playing the mpeg file on the tv?
Your second link in the last post is a high def export. It should look much better. It does. But it also shows the only problem I see in the others - the combing like appearance that makes me wonder about interlacing. (I am viewing the mpeg/m2v on vlc, and setting deinterlace on removes this).
Message #1 in http://forums.adobe.com/thread/1120039 is a picture example of the screen size at various resolutions
Down scaling from HiDef to DVD throws away a LOT of information... so a DVD will never look as good as a BluRay
If you play a DVD in an upscaling player it will be "somewhat" better than a regular player
WHO CAN EXPLAIN ME WHY I GET a VERY GOOD VIDEO QUALITY, WHEN I SET THE EXPORTING SETTINGS INTO "MATCH SEQUENCE SETTINGS" in ADOBE PREMIERE PRO?
I get the a relative big output file in MPEG format.
Then, if I use this output file in Encore and transcode it, the file becomes very poor video quality.....WHY?
Thanks in advance.
The one you posted above like this retains its HD pixel size (1920 x 1080). It is not DVD size (720 x 576).
Encore must reduce it to 720 x 576.
OK, what is the solution?
Ann has pointed to the solution a couple different ways. Export from Premiere as a file that does not require Encore to retranscode it. Maximize your bitrate. Or dynamic link to Encore as automatic.
Judge the quality on an HD TV only from a butrned disk using an upscaling DVD player.
You are complicating this by exporting HD quality files and focusing on the different between HD and SD. We are having difficulty addressing the quality of specific files.
Because in this case, Match Sequence Settings creates a high definition output. DVD requires a standard definition file, so there will be quality loss.
Hi Ann,
the exported MPEG file (Match Sequence Settings) are available now in the link
Regards
Hi Ann,
I uploaded a part of the original recording file (.MTS, about 93 MB). You can download it from
http://www.klavierlehrer-bayern.de/download/2012_Weihnachtsmusikcal_Sc hule_13-12_1.MTS
Regards
Claudia
I tried many options, also Ann's suggestion.
Bad quality...
What are you describing as "bad quality"? Other than the combing I am describing, your DVD sized piece (and the one I exported using your full pixel size download) are not "bad" for DVD quality.
You seemed to not understand the effect of keeping the full pixel resolution n the PR export, so I am not sure you are correctly assessing what you have.
Have you burned a disk and watched?
North America
Asia Pacific
