HeyItsJono
PS CS6 installed instead of CS6 Extended
Dec 27, 2012 10:08 PM
Hi there,
I downloaded the installer for the trial of Photoshop CS6 Extended, however upon installing it and using the trial, I do not have access to the 3D menu or any other Extended features. When the program starts up, it only reads Adobe Photoshop CS6 and the About Photoshop popup in the Help menu reveals it to be CS6 instead of Extended. Have I taken a wrong turn somewhere? I had problems with the download manager too in that after signing into it with my account the download did not immediately start and instead I had to select Photoshop CS6 from the list within the manager. Any help would be much appreciated, thank you!
    Dec 27, 2012 11:20 PM   in reply to HeyItsJono
    Which other Extended features are missing?
    Your computer might lack the proper GPU for the 3D features.
    The trial should always be Extended and the Extended features be »inactivated« on registration with a basic license.
    Maybe contributors on this Forum might be able to help:
    http://forums.adobe.com/community/download_install_setup
    Dec 29, 2012 11:25 AM   in reply to HeyItsJono
    Just because it worked in CS5 does not mean it will work in CS6.  Needs better GPU drivers.  What OS?  If XP it needs SP3 I believe.
  • Noel Carboni
    Dec 23, 2006
    Dec 29, 2012 6:34 PM   in reply to Curt Y
    FYI, I don't believe 3D functionality is available at all from Photoshop CS6 in Windows XP, no matter what the service pack.
    -Noel
    Dec 29, 2012 7:21 PM   in reply to Noel Carboni
    That is correct - no GPU functions are enabled on XP in CS6 (and future versions of Photoshop will not support XP).
    Dec 31, 2012 10:28 AM   in reply to HeyItsJono
    Then the choice of Extended or standard comes down to which serial number you enter (or Creative Cloud which is always Extended).
  • Noel Carboni
    Dec 23, 2006
    Dec 31, 2012 11:27 AM   in reply to HeyItsJono
    Are you seeing the 3D menu grayed out, or is it just missing?
    Very occasionally we hear from folks who say the Photoshop trial does not expose the Extended features, where they really should be showing.
    I don't ever recall hearing a workaround or why this might happen.  Did you download the software directly from Adobe?  Is there any chance it's set to run in compatibility mode for XP?
    -Noel
