Jeff_Fuhrman
Premiere Elements 9 will not add video to timeline
Dec 28, 2012 5:52 PM
Premiere Elements 9 will not add video to the timeline or sceneline.  I've tried MOV, AVI and MTS files.  They all play when double clicked in the Organize tab.  I'm using Windows 7, have 39GB free on the C: drive, and the video and scratch files are on the D: drive.  Suggestions?
    Dec 28, 2012 5:59 PM   in reply to Jeff_Fuhrman
    Moving this to the Premiere Elements forum. Not many of us here in the PSE forum use PRE.
    Dec 28, 2012 6:33 PM   in reply to Jeff_Fuhrman
    Is that D drive a separate, physical drive... or a partition on the C drive?
    If that IS a partition... read http://forums.adobe.com/thread/650708
    Also, I have read that PreElements requires you to have Quicktime installed
    Dec 29, 2012 8:26 AM   in reply to Jeff_Fuhrman
    What happens if you use Get Media to import the clip to your project?
    (You can't add a clip directly from the Elements Organizer's Media Browser to your timeline.)
    Dec 29, 2012 2:03 PM   in reply to Jeff_Fuhrman
    If you're seeing a purple triangle with a P in it over the clips, then you are in the Organizer Media panel. You need to click on the Project button under the Organize tab to see the clips that are actually in your project.
    You should be able to drag the clips from the Project panel to your timeline.
    Dec 30, 2012 7:23 AM   in reply to Jeff_Fuhrman
    You shouldn't need to do that -- but, if it worked, that's all that matters!
