fuzzy pictures in bridge preview
Dec 29, 2012 8:23 AM
Tags: #bridge #fuzzy_images
Some of the pictures in preview window comes out fuzzy, I cleared the cache several times, but didn't help. Any suggestions? Fuzzy pictures opens up in Photoshop fine.
Photoshop version CS6 13.0.3X64
Mac OS 10.8.2
    Dec 29, 2012 3:53 PM   in reply to Sarpel
    What kind of files are you previewing?
    Dec 30, 2012 6:48 AM   in reply to Sarpel
    What do you have set in your options for thumbnail and preview quality?  Always High Quality?
  • Omke Oudeman
    Nov 27, 2004
    Dec 30, 2012 9:29 AM   in reply to Sarpel
    am I right?
    No, you are wrong, the main difference between Bridge CS5 and CS6 is the transition from 32 bit to 64 bit, a different cache structure (again) and a few minor improvements, nothing further.
    And if CS6 did not offer the quality settings it would be next to useless...
    Dec 30, 2012 10:46 AM   in reply to Sarpel
    Check Always High Quality in the Options For Thumbnail Quality And Preview Generation button in the Adobe Bridge application bar:
    Dec 30, 2012 11:20 AM   in reply to Sarpel
    Generate Monitor-Size Previews might be one more option to try:  Edit > Preferences > Advanced
    Dec 30, 2012 11:42 AM   in reply to Sarpel
    Try unchecking it.
    If that doesn't help then perhaps you could describe what might be different in the psd files that appear fuzzy in preview contrasted with the tiff that display OK in preview.  Pixel dimensions?  Color?  Do they appear different if you display two or more in preview vs only one? .. if you display one tiff and one psd together in preview?
  • Omke Oudeman
    Nov 27, 2004
    Dec 30, 2012 2:35 PM   in reply to Sarpel
    Two or more previews, fuzzy ones stay blured, other ones sharp.
    Just for experiment, try select a fuzzy thumb and with right mouse click choose 'purge cache for selection' and see if this helps.
    Otherwise can you add a screenshot of the problem to clarify more?
