Since updating to Lightroom 4.3, I cannot access the Slideshow module. Each time I try, I receive the following message:
"An error occurred when attempting to change modules."
I have researched the problem and been offered suggestions to solve the problem. I have followed instructions to resolve the issue including:
The problem still persists. Does anyone know of a solution beyond what’s stated here?
I've disconnected it and shut completely down. When I reconnect the second monitor, the same problem persists...that is, it shows an error occurred when trying to change modules. If I use the two monitor feature in Lightroom, I can access the Slideshow module on the second monitor, but I don't have any control over anything there. It offers only the default setup. I'll hang in waiting for a fix. Thanks for looking into it Victoria.
I am running OS 10.8.2 with LR 4.3 and I discovered this problem just the other day. I have reinstalled LR 4.3, temporarily moved all homemade slideshow presets, moved all preferences (as if they were deleted) and the problem persisted. So I tried disconnecting my second monitor (I have a 27" iMac with my second monitor being the 30" Cinema Display.) I got out of lightroom and restarted with the Cinema Display disconnected and the slideshow module worked just fine. I quit Lightroom again and reconnected my monitor and restarted the program and the slideshow module did not work. So for my situation and testing, the problem with the slideshow module exists while having the second monitor connected.
I can report the same problem - running a MacBook with Mountain Lion 10.8.2 and a second monitor display and LR 4.3. Same issues - can now only get slideshow if disconnect secondary monitor or move main LR interface to main screen and run slideshow on secondary screen separately. Quick fix please!
GUYS! I have tried everything and was on the phone with Adobe for over 2 hours! None of these suggestions worked but I just cracked the code for my situation. On OSX 10.8.3, the Libray is hidden so hit "control" while in finder and click on the Library icon. Then, click "get info" on the library icon. Then, unlock the permissions on the bottom of the get info window and make sure all the users have "read/write" access. I also added "Admin" since it wasn't in there. Make sure you click the settings wheel and "apply the changes". This worked instantly for me. I really hope this helps you all! Good luck!
I have two Macs; a G4 and MacBook Pro. I tried this solution at the office with Lightroom 4.3 and voila ~ ! Success. I was excited to go home and apply the same solution to my MacBook Pro. When I did, the same old blank screen appeared. Weird, huh? Needless to say, I re-installed LR 4.2 until Adobe can get off their butts and fix this. What in the world is the hold up Adobe????????????????
North America
Asia Pacific
