I have been using PE10 for some while now. One thing that I have noticed is that when you put together clips there is a silent gap on the soundtrack which lasts about 3-4 frames. I use MTS files. When you add another clip to an existing one- if you go through the transition from one clip to the next frame by frame there is a short gap of 3/4 frames with no sound but still the picture. Currently I cut the next clip after I gone though it frame by frame until the first frame when the sound reappears. I them delete that small section and when the remaining clip automatically shifts and joins the previous clip I get an unbroken sound and picture transition. But I am curious as to why PE should introduce this silent gap in the first place. Any ideas?
cheers
bill
As well as what Steve said, this may help explain why... http://forums.adobe.com/thread/1015001?tstart=0
Read message #3 in http://forums.adobe.com/thread/1124354 for a possible solution
Thanks for the link. Is the solution to try using that tsMuxeR program or is there a better way of importing the clips into PE? Once I download the files/folders off the SD card from the camera I format the card ready for new recordings. So the only copies are on the main HD and backup external HD.
When I use PE I use its "Get video from files and folders" option to find the files which are located in the Stream folder.
North America
Asia Pacific
