I am using Photoshop CS6 on a Mac, OS 10.8.2. When I go to File/File Info... and look for the date a photo was created, I only see the time to the level of minutes. I need to know to the level of seconds. I believe earlier versions gave this information.
Photoshop version is 13.0.1 x64
OS is OS X 10.8.2
File is from my Canon 1Ds
I finally figured out how to have CS6 display the time in seconds. First go to the Apple menu and select System Preferences, Date & Time. Then click on "Open Language & Text", click on "Region", and click on "Times/Customize". You will see 4 selectable options: Short, Medium, Long, and Full. Here is where it gets confusing. OS X ignores which option you choose; only the Short option is used. The Short option is initially set to not display seconds. So type in a colon and drag the oval icon from one of the other options to the Short option. Then click OK. Now when you select an image file and press Command I, you will see the creation date with seconds. Photoshop will now also display the creation time in seconds. Photoshop rounds off differently than OS X, so the actual value will sometimes differ.
In my opinion:
1) It would have been better for Apple to use a less confusing method to select the style of displaying the time
2) Adobe would be better off not relying upon the operating system to get the creation time of the file. That information is provided by the camera, and is incorporated in the file.
Thanks for the advice about updating. I did the update, and found that Photoshop still relies upon OS X to decide whether to use seconds or not. A related question is:
why when in Photoshop, I go to File/File Info... and click on Camera Data, do I not see any date information, in spite of the fact that the camera has that information? I do see the creation date under Description, Audio Data, Origin, and Raw Data. This seems odd. Is there some way to add the date information to the Camer Data field?
On my Canon 5D Mark II, I see the time to milliseconds. On my older 1Ds I see the time only to seconds. Also, I can set the date and time to any time zone I want on my cameras. When I create a "photo" the camera tags the file on the camera card with the current time. The camera thus is responsible for the date of a photo and its precision, as well as the ISO, speed, and aperture. The date therefore should be included under the Camera Data tab, as it used to be in earlier Photoshop versions.
Earlier I mentioned the issue of rounding off when displaying the number of seconds. Also, Conroy brought up the subject of milliseconds in Photoshop's File Info... I did a little comparison of Apple's time tag and Photoshop's "milliseconds". In the list below I compared the time from Apple's Command I to the time from Photoshop's File Info.../Advanced for a sequence of 15 photos.
Camera File Cmd I File Info…
5D II IMG_1639 3:50:14PM T15:50:14.069
5D II IMG_1640 8:26:44AM T08:26:44.021
5D II IMG_1641 8:26:48AM T08:26:47.091
5D II IMG_1642 8:27:32AM T08:27:32.003
5D II IMG_1643 8:31:18AM T08:31:18.092
5D II IMG_1644 8:31:20AM T08:31:21.002
5D II IMG_1645 8:32:10AM T08:32:09.087
5D II IMG_1646 8:32:12AM T08:32:12.051
5D II IMG_1647 8:32:28AM T08:32:29.033
5D II IMG_1648 8:32:36AM T08:32:36.048
5D II IMG_1649 8:32:46AM T08:32:45.081
5D II IMG_1650 8:32:48AM T08:32:48.071
5D II IMG_1651 8:33:22AM T08:33:21.085
5D II IMG_1652 8:34:42AM T08:34:42.042
5D II IMG_1653 8:34:44AM T08:34:43.046
Apple always makes the least significant second an even number, in spite of what Photoshop says it should be. But the three digits to the right of the decimal point for Photoshop's time always begin with a 0. The probability that the beginning tenth of a second is always zero is very small, 1 part in 2 to the 15th power or 1 part in 32,768. Those 3 digits may not actually be milliseconds.
I tried looking at File info... with Photoshop CS2 on files from my 1Ds and 5D II. They show the time in seconds under Camera Data 1. There is no bogus "millisecond" information that shows up. The nice thing about CS2 us that all the information from the camera shows up directly upon selecting File info...
North America
Asia Pacific
