Hi all,
I am attempting to hook Flex up to the LCDS engine installed
with CF8. I can get the ds.fill() method to populate an
ArrayCollection just fine, pump the data out in a DataGrid and
shows perfectly. However, when I update a record in the datagrid I
get an error indicating that "Error during update: The OLDBEAN
argument passed to the update function is not of type" and then it
says my CFC type.
I changed to code to set autoCommit to false and update one
entrry via code then manually call commit, and this works fine,
although I did have to cast the single record to my data type (it
was a generic Object). Setting it back and debugging shows that all
of the records in my ArrayCollection are typed as generic Object's
not as my defined data type.
My question is: how do I get the ds.fill() method to return
the correctly typed objects (I am using the CF8 wizard-generated
CRUD arguments)
OR
How can I programatically convert the contents of the
ArrayCollection to the required type "on-the-fly" before calling
ds.commit()?
Hoping somebody can help, this is driving me nuts!
Just as a final thought, does this indicate a bug in the CF
CRUD generation wizard or am I just doing it wrong?
Cheers,
Owen West
HNE Health
owen.west@hnehealth.nsw.gov.au
