Back Button on Photo Slideshow not working properly?
Jan 1, 2013 2:12 AM
Tags: #action_script_3 #newbie #flash_professional #cs6 #back_button #photo_slideshow
Hey y'all,
I am currently working in Flash Professional CS6 using an AS3 sheet thing. . . I'm incredibly new to flash, and I've encountered a problem google could not solve.
Here is my project (not in its proper dimensions on the screen, so please ignore the pixelated pictures): http://myfirstphp.hostzi.com/slideshow2.swf
So, the goal was to tween transparancy each photo which would loop continuously. I also wanted to add next, back, pause, and play buttons that would appear when hovering over the stage. Well, I got everything to work except the back button.
For some reason unbeknownst to me, whenever you hit the back button a few times (more than twice or you hit the next button then the back button), it doesn't go back. It's like the button doesn't reload to the proper frame. Strange to me.
The next button seems to be working perfectly, however. So why just the back button? I don't know!
I have my flash project set up as the following (this may not be the most efficient way, but I could not find another way to do it; hopefully this makes sense):
Each picture is in its own layer. Each layer is transparency tweened. The layers are staggered in order to fade into each other.
I have two action layers.
The first action layer has my play, pause and alpha channels. This keyframe encompasses the entire slideshow. Below is the code:
pause_btn.alpha=0;
play_btn.alpha=0;
forward_btn.alpha=0;
back_btn.alpha=0;
rectangle_btn.alpha=0;
stage.addEventListener(MouseEvent.MOUSE_OVER, mouseOverHandler);
stage.addEventListener(MouseEvent.MOUSE_OUT, mouseOutHandler);
function mouseOverHandler(e:MouseEvent):void
          pause_btn.alpha=1;
play_btn.alpha=1;
forward_btn.alpha=1;
back_btn.alpha=1;
rectangle_btn.alpha=0.5;
function mouseOutHandler(e:MouseEvent):void
          pause_btn.alpha=0;
play_btn.alpha=0;
back_btn.alpha=0;
play_btn.addEventListener(MouseEvent.CLICK, fl_MouseClickHandler);
function fl_MouseClickHandler(event:MouseEvent):void
          // Start your custom code
          // This example code displays the words Mouse clicked in the Output panel.
          play();
          // End your custom code
pause_btn.addEventListener(MouseEvent.CLICK, fl_MouseClickHandler_2);
function fl_MouseClickHandler_2(event:MouseEvent):void
          stop();
My second action layer has my next and back buttons in them. I have a new action keyframe on the start of each tweened picture. Below is the code for one of the keyframes (note: the only thing that changes are the numbers in each keyframe):
forward_btn.addEventListener(MouseEvent.CLICK, click1);
function click1(event:MouseEvent):void
          gotoAndPlay(21);
back_btn.addEventListener(MouseEvent.CLICK, click0);
function click0(event:MouseEvent):void
          gotoAndPlay(229);
I'm not sure what else y'all need to help me solve my problem, so I guess I'll just check back in the morning Thanks so much in advance!
    Jan 1, 2013 5:27 AM   in reply to Freckles
    Based on you showing specific frame values I assume you assign new listeners at different points along the timeline.  If you are not removing older listeners then chances are they are still assigned and at work when you try to use the button which is likely to be the problem.
    You should take a different approach and just have one set of listeners working for your buttons.  Make use of a variable whose value you change as you move along the timeline instead of assigning new lsiteners at each point.
    For example, in frame 1 (or the first frame where your back button starts)....
    var backReference:Number = 1;  // 1 is for frame 1 since you can't go back further than 1
    back_btn.addEventListener(MouseEvent.CLICK, clickBack);
    function clickBack(event:MouseEvent):void
              gotoAndPlay(backReference);
    Then, for each subsequent frame where you have a new image starting you only need to assign a new value to the backReference variable relative to the image before it.
    Doing it this way you only need to ever have one event listener assigned to the button and one event handler function as well.  You only change the value of the variable that the function uses.
    Jan 1, 2013 11:36 AM   in reply to Freckles
    You can only declare a variable once.  Any other time you just use it...
    frame 1:       var backReference = 1;  // declared
    frame elsewhere:   backReference = ...    // just assign its new value
    Jan 1, 2013 2:09 PM   in reply to Freckles
    You are doing the same thing you were originally... creating multiple listeners for the button.  You only need to have the functions defined once in the first frame where the button(s) starts.  That actions layer needs to extend the full length of the timeline so that the variables and functions are available throughout.
    The single button instances can extend the full length of the timeline without having to have more than one keyframe for them.
    Frame 1
    var nextReference:Number = 21;
    var backReference:Number = 229;
    forward_btn.addEventListener(MouseEvent.CLICK, clickNext);
    function clickNext(event:MouseEvent):void
              gotoAndPlay(nextReference);
    Other Frames:
    nextReference = 46;
    backReference = 253;
    Jan 1, 2013 3:22 PM   in reply to Freckles
    You're welcome
