Chris Hembel
What happened to Find/Change Special Characters
Jan 1, 2013 8:41 AM
Tags: #bug
I am a recent update from FrameMaker 9 to FrameMaker 11. I use many notations with non-breaking hyphens and non-breaking spaces. In version 9 I was able to use the hex codes in the Find/Change dialog box and find and replace those notations. Now in version 11, it does not find those characters. I end up finding more than I want.
For Example: I want to find
(E-Vote Sept. 12, 2008)
This text has a non-breaking hyphen and the spaces shown are non-breaking also. When I entered these characters into the document, I used "Esc hyphen h" key sequence for the hyphen and "Control+space" for the spaces.
When I enter "(E\x15Vote\x10Sept.\x1012,\x102008)" and press the Find button, FrameMaker converts the text to "(E\+Vote\s#Sept.\s#12,\s#2008)" and returns with a statement "Not Found." I get the same error if I copy the text and paste it into the Find/Change Dialog box. I have tried this with the "Consider Case," "Use Wildcards" and the "Whole Word" checks both off and on. I can't get it to find it.
Honestly, I never noticed if verstion 9 did the conversion, from \x15 to \+ and \x10 to \s#, in the Find/Change dialog box because it always found what I was looking for.
I hope someone can tell me how to fix this because this is a function that I use all the time in FrameMaker. I use non-breaking hyphens and spaces all over my documents.
I have also reported this as a bug because that is what if feels like to me. I did go out and updated my installation of FrameMaker, thinking that this may have been reported and fixed already.
One Sad FrameMaker User
Chris
    Jan 2, 2013 7:07 AM   in reply to Chris Hembel
    I'm not sure this is what you're looking for, but you could;
    Copy your 'E-Vote Sept. 12, 2008' text
    Go to Find/Change
    Select Text & Character Formats on Clipboard from the dropdown menu
    Click Find.
    Jan 2, 2013 7:50 AM   in reply to Chris Hembel
    FM is just trying to substitute in the appropriate dialog box codes for the display and find.
    The codes can be found here: http://help.adobe.com/en_US/framemaker/using/WSd817046a44e105e21e63e3d 11ab7f7862b-7fd5.html
    The non-breaking hyphen is "\+" and a non-breaking space is "\ ".  You can also use the unicode values (\unnnn) to find these. A non-breaking space is 00A0 and the non-breaking hyphen is 2011.
    Jan 3, 2013 2:26 PM   in reply to Chris Hembel
    Chris,
    As I stated in my reply, to find a non-breaking space, use "\ " [that's a backslash and space] to find a non-breaking space.
    Jan 3, 2013 3:27 PM   in reply to Chris Hembel
    Chris,
    That's odd. It (dialog-box codes) works for me on my systems:
    Using the dialog-box codes works perfectly. The unicode values for the non-breaking space (nbsp = \u00A0) and non-breaking hyphen (\u2011), however, aren't working. It looks like the wrong glyph is being substituted in both cases.
    This is definiely a bug when doing a unicode-value search.
    Jan 4, 2013 10:35 AM   in reply to Arnis Gubins
    Chris,
    I just noticed that you were using \x10 for the non-breaking space. That's actually the numeric space (\s# in the dialog-box codes). The non-breaking space in FM is \x11. See: http://partners.adobe.com/public/developer/en/framemaker/Character_Set s.pdf on p.3 for the proper hexcodes.
    Otherwise, as I mentioned in the previous reply, if I continue to use the dialogue box codes, I don't have any issues in FM11 finding the special symbols. Using the unicode values is a bit dodgy though.
