In LR4 when I burn my slideshow video to a USB and play on my TV, the slideshow works fine but the mp3 music skips during transitions. Played on the PC music is fine. I am using 'fit to music'
I suggest bandwith problems with your generated video. E.g. a DVD only allows 9 Mbit for video + music. There will be some limitations on your video / tv player concerning bandbith. Smoth transitions require a lot of bandwith!
BAndwith limitations on modern cpu / gpu are much higher.
What can you do? E.g. Reduce the mp3 bitrate or use wav (no decoding needed).
Great ideas to try - Thanks!
I was going to try not doing 'fit to music' to see if that helps, but converting my mp3 to WAV sounds promising. It's a 40 minute mp3 where I splices about 10 shorter mp3's using Audacity.
I am burning to a 4 GB USB and playing the video from the USB input on my 42" Vizio TV, when I burn to a DVD and try to play it skips much worse. On the USB it skips about 2 or 3 times during each individual MP3 that was spliced together, although the first 3 mp3's doesn't skip at all, only the last few.
Regards,
Allen
Well, LR4 will not use a WAV file, and when I changed the bit rate from 128 -> 64 in my mp3 it said invalid file format when I tried to add it to my video.
What do you think about me converting the mp3 to mp4a ? That's a supported file format, and there are free converters available. Would that be worth trying ?
The background music isn't that important, it's just for some atmosphere for the slideshow video.
I would try to find out if there are some limitations about bandwith and H264 Vizio. I did not find anything in the manual :-( Ask the support.
Did you tried an other USB stick?
Perhapst you can shorten the fade in / out of the pictures a little bit. This produces the burst in bandwith. Perhast there is a too small buffer in the Vizio for your video with produces problems in loading data (music).
I
>> Did you tried an other USB stick?<< - Yes, several
>>Perhapst you can shorten the fade in / out of the pictures a little bit.<< - I will try that next!
>>small buffer in the Vizio << I need it to work for all large flat screen TV's because it is going to be marketed as a big screen slideshow
The thing is that if I just play the soundtrack on the TV, it works fine with no skipping. I am wondering if my images might be too large. They are all 300 DPI JPG's and about 5,000 pixels at about 10 megabytes, and there are 276 of them for playing the video for about 40 minutes.
I could convert the mp3 to mp4a and add that format as the soundtrack.
Thanks for all of your input,
Allen
When you export to a video file from Lightroom's slideshow module, Lightroom reencodes the audio to mpeg4 audio automatically. However, Lightroom is not very smart about the video bit rate and often goes over what some types of media allow. What I do is run the output video file through Handbrake to reencode to a more compatible file that will play from almost any device.
North America
Asia Pacific
