JLLPhoto
Edited photos in LR 4 not moving over to CS5
Jan 1, 2013 1:14 PM
I just upgraded to Lightroom 4 this week and am haing trouble getting CS5 to open the Lightroom-edited photos.  For example, if I adjust the exposure, clarity, etc. in LR 4 and then hit command E to take the file over to Photoshop for further editing, CS5 isn't opening that edited file.  It is opening the original file that was imported into LR 4 but not the edited version.  These are RAW files.
Interestingly, all of the older files that I originally edited in LR 3 (they have now been moved into the LR4 catalog) will still move over from LR4 to CS5 when I hit command E.  Only the files that were imported  from my camera card directly into LR 4 aren't cooperating.
Any ideas?
Jason
    Jan 1, 2013 2:35 PM   in reply to JLLPhoto
    When you hit Cmd + E - or right-click the photo and select Edit in CS5 you should get a dialog box that gives you two options:
    1) <Open anyway>, and
    2) <Render using Lightroom>.
    If you select (1) CS5 will open the original without Lr adjustments,
    if you select (2) Lr will send a PSD to CS5 with all your Lr adjustments.
    If you don't get this dialog because you have suppressed it, go >Edit >Preferences >General tab, and under the section "prompts" click on <Reset all warning dialogs>.
