Bear with me, as I need to state my problem in Quark terms. (A long-term Quark user and lover, I'm now at the tipping point and actually prefer ID for most things, but this is still foxing me.)
I am working with XTags to place text and images on a page. There is a complicated arrangement of linked text frames (24 of them) to enable this to happen. If I have a single page document and import the text, it all flows perfectly. But if I am importing more products than there is room for on a single page, I want InDesign to insert a new page with the same frames.
If I put the frames onto a master page (which is what I'd do in Quark) they become 'locked'. I know how to Override Master Page Items, but I don't want to do that. I want a new page to appear and the text to flow onto it without intervention. This was so easy to do in Quark. I know I'm probably approaching it the wrong way, but I need some help!
To summarise, I have 24 linked text frames on a page (to accommodate 12 products and images). If I have 48 products, I want the next 24 to appear on a second page. I don't want to create a multi page document - this is a template and will be re-used over and over, sometimes for a single page, sometimes for many pages. If I need to adjust the positions of the text, I want to do that in a single place and know it will happen throughout the document.
Is there any way of doing this?
Emma
The source is a text file, imported using Emsoftware's XTags plug-in (correct terminology?) - text, styling and images are all embedded in it. So it can't be imported via 'Place' but must use the 'Import text with XTags' command.
Master Text Frame seems to do what I want for a basic layout, but not for the complex one I need. Not sure if this will help...
- this is the 'simplest' version with 4 products per page. The images go at the top of the page and the description at the bottom.
I wouldn't go back to Quark for anything if I had a choice, but that's me. I do books in ID about once a year, no problem, and without benefit of any third-party plugins. It sounds to me like your project is more of a catalog, and there are dedicated third-party solutions for that, including one from Em.
I'm pretty sure that waht you want to do is straight-forward, but I have no experience with your plugin so I can't begin to tell you what more you need to do.
North America
Asia Pacific
