The stabilizer effect seems not to work correctly on my videos, even not in the default settings.
The result is worse, jumping frames, some of them are tilted, and the rendering takes a lot of patience and long long waiting.
Any idea how to do it better?
Peter
What model of camcorder is your video coming from and what format and resolution is it?
Which version of the program are you using and one what operating system? How fast is your processor and how much RAM do you have?
What is the subject matter of your video? Is it relatively stable content, like someone standing at a podium speaking, or something with a lot of movement and continually changing content? Can you post a sample clip of your results and post a link to it so we can see it?
Dear Steve, here my answers:
à Sony HDR-HC7 , MPEG, 25 fps, 1440x1080
à APE10, Windows 7 64bit, i7 940 2.93 GHz, 4GB RAM (checked the RAM, still about 1 GB is free during heavy use, except APE10 runs in a hang-up) & SSD 240GB Kingston Hard with SATAIII and 600MBs.
à It’s the second one, I follow my kids doing sport, but we did that very shaky and would like to have more continuous movements of the camera.
à Sure, but where can I put the sample (on youtube ?) so that you can access it with a link?
Thanks! Peter
Since your camcorder is HDV, I assume you captured your video by connecting it to your computer with a FireWire connection and then using Premiere Elements' Capture tools to get the video. And I also assume that, when you started your project, you set it up for HDV 1440x1080 (not AVCHD). Am I assuming correctly?
Since the Stabilizer builds its stablizing corrections on a subject or color it identifies in the middle of the frame, it's much less effective at following action. Particularly if there's a lot of blurred movement and a lot of handheld shaking.
But we'll be able to diagnose more once you post your video to YouTube or Vimeo and then post a link to it on this forum.
Dear Steve, here the video.
The first scene with Stabilizer, default settings, the second scene without. Not much a difference, isn’t it? For me the stabilized scene is maybe even worse than the non-stabilized.
To your question: Yes, I captured the video by FireWire and the project setup is HDV 1440x1080 (not AVCHD).
Peter
Your results looks about right for default settings for the Stabilizer.
What happens if you change the Applied Effects settings?
Remember, that the Stabilizer is just math, not magic. So the more corrections the Stabilizer needs to add to your video, the more the program has to cut off the edges and zoom in and the lower the quality.
Dear Steve,
I changed the applied effect setting toward stronger smoothing, up to 100%. But the results are getting worse.
Dear Ann,
Thanks for your comment. So I understand this type of video is not suited for the Stabilizer because it’s too shaky. To yor question: What is OIS (sorry, I’m a beginner in APE)?
Peter
Thank you Steve, I understand that might be the best option to use the Sony’s HDR-HC1E stead shoot setting, which I don’t remember if it was turned on at that time.
But the whole exercise is about having optimizing old video footage and I still don’t give up and will check some other tools to see if shaky videos can be stabilized better that APE10 can do it. Funny that even Youtube is asking to improve the video related shakiness while uploading, I might test how good they are in fixing that problem. J
However I have to confess that today I use the Sony Balanced Optical Steady Shot and this is a huge improvement!
Peter
North America
Asia Pacific
