AlanFischer
Reconnect Missing files, file already exists
Jan 2, 2013 5:25 AM
Tags: #organizer #photoshop_element_11
I have moved a catalog of 150'000 pictures (with associated pictures) to from an iMac to a new Macbook Pro. I used (in Elements 11, same version on the old system) "reconnect missing files" to update the path to the new location. Most files did reconnect perfectly. However, some of them cannot be reconnected. The message I get is
"The files cannot be reconneceted because the file already exists".
The reality is that the same file does not exist. Only an identical named file in a completely separate directory path form another year is present (I use more than one camera and the filenames start all at DSCN001.jpg). How can I fix this, otherwise I cannot complete the transfer of the library.
    Jan 2, 2013 6:02 AM   in reply to AlanFischer
    I am not a mac person but it seems to me the better way would be to do a backup from machine 1 and restore it to machine 2. That way everything should be the same.
    Jan 2, 2013 7:28 PM   in reply to AlanFischer
    I do not have the knowledge to answer your reconnecting issues. Maybe someone else can chime in with a suggestion.
    Question: Are your pictures on an EHD? I don't think so, just checking.
    Since I cannot come up with a solution other than to do a backup/restore I am afraid I can't be of much help. If you get this sorted out I would recommend putting the catalog and the pictures on an EHD and then you wouldn't have this problem in the future. You would be able to move the EHD from one computer to another.
    Perhaps it is time to contact Adobe and see what they say.
    Jan 2, 2013 10:08 PM   in reply to AlanFischer
    When you took backup, did you choose to maintain Folder Tree hierarchy?
    It is always advised to do reconnect before taking backup.
    Anyways, once you restore (as many pictures as possible), import all images from your backup folder directly using File >> Get PHotos and Videos. Let's see if the duplicate (which are being left out upon restore) are imported or not.
    Otherwise I would suggest a Full backup once again maintaining folder tree hierarchy, on your old machine and then restore on the new machine.
    Andaleeb
