lithodora
Keyboard Shortcut to run System Services [Mac]
Jan 2, 2013 11:07 AM
Tags: #cs5 #mac #mac_os_x #keyboard_shortcuts #system_services
In Indesign (and everything else) under the Application Menu there is a 'Services' sub menu. I want to be able to use the keyboard shortcut for one of them but Indesign does not seem to recognize it and I am unable to assign it.
I should be able to type a formula (ie. 12+3) into a text frame, then select the text and solve it by pressing CMD+*. InDesign does not recognize the shortcut though. If I have the text selected and use the mouse to select the menu it solves the equation.
Is there anyway I can access that without writting a new script to do what already exists?
  • John Hawkinson
    Jun 25, 2009
    Jan 2, 2013 11:30 AM   in reply to lithodora
    The Services menu is controlled by the OS, not by InDesign. So bind theshortcut in System Preferences > Keyboard > Keyboard Shortcuts.
    I believe you have to pull down the Services menu with the mouse (so that the shortcut is visible) before it will be active.
