sjbreier
Yin/Yang symbol, vertical line.
Jan 2, 2013 8:26 PM
Tags: #yin #yang #tao
I created a Yin/Yang symbol, but for some reason it has a vertical line through its center.  The line disapears sometimes after I move the symbol.It disapears in outline mode.  Why is it thre?  How do I get rid of it?
    Jan 2, 2013 9:22 PM   in reply to sjbreier
    A couple of things that I can think of that would cause it, are objects overlapping or are not quite touching,
    Jan 2, 2013 9:24 PM   in reply to Silkrooster
    It may be noticible if you applied a stroke to both objects, then it should be noticible in the outline mode.
    Jan 3, 2013 1:33 AM   in reply to sjbreier
    That may have to do with how you created the shapes in teh first place. Could be some leftovers from a Pathfinder operation... Screenshots would help.
    Mylenium
    Jan 4, 2013 4:28 AM   in reply to sjbreier
    If you have a look at the strokes (ctrl Y), you may have one vertical stroke.
    Or, and it is often the case in illustrator, if you have cut a circle in two parts (top left black one and the bottom right white one), you should be sure to have the length and the x position of these 2 demi-circles as entire numbers (without comma).
    You can see the antialiasing by zooming in a pixel display mode (shift + ctrl + y).
