<rant>
It was a good day... I only lost 30-45 min of work this time, and sadly, the Fireworks auto-panic-save produced garbage.
Im a creative cloud subscriber, and I rely on Fireweworks daily to earn a living. But I'm about at the end of my rope with this product.
Photoshop is not an alternative for the type of work I do, yet I feel that is where Adobe is trying to lead us. Fireworks CS6++ needs a re-write, simply bolting un-needed new features to this 32-bit Frankenstein wont cut it.
Same behavior from two different Mac-Pro's (home / office), running two different versions of OSX (10.7x / 10.8x).
</rant>
I have given Sketch a shot, and I feel like it's just as buggy, if not more buggy, than Fireworks.
BigMucho,
I too rely on Fireworks every day for work and too experience the daily crashes. It really is a shame that the only product designed to for interactive work is filled with so many issues.
The only thing I can recommend (and i highly recommend you do) is enable autosave. I have mine set for 5 minute increments, so at most I lose 5 minutes worth of work. Just make sure you save the document before you start working on it, so there is an file to be autosaved.
It's really pathetic that I have to use such a hack of a fix just to make Fireworks functional. Hopefully either Adobe gets its act straight with Fireworks, or another product (like Sketch) comes along as a proper replacement.
@growing: Would you mind sharing how you enable and adjust the "auto save" settings? I see online that it can be edited directly from within a Preferences text file, as well as by using some type of command panel extension. But these seem like "back door" approaches. Is there a "front door" method to accessing this somewhat under-documented feature?
@groove25,
Unfortunately there is no "front door" approach from within the Fireworks App to enabling auto save. But it is a really easy fix from within the preferences file. Just do an "cmd + f" search from within the file for "autosave".
http://stuffandnonsense.co.uk/blog/about/turn_on_fireworks_cs6_auto_sa ve
Here is the tutorial I used. Like in the tutorial, I left my auto save time increment at 5 minutes, which works perfectly for me.
I hope this helps and saves you some frustration as it has for me.
North America
Asia Pacific
