To be precise, I want to recreate this button in Fireworks (original here):
I created a rectangle with the stroke set to the dark orange color, and the fill to the light yellow color. Then I wanted to add a white inner shadow with 50% opacity to make the effect that's visible in the inner top, left, and right edges. However the shadow is also affecting the stroke. Is there a way to make it only affect the fill?
Thanks.
Actually, you can control the stacking order of filter effects. So you could apply the Inner Shadow effect to the object without the stroke, and then add the Stroke via the Photoshop Live Effects (at the bottom of the Filters menu).
Both this and the Gradient Fill options would allow you to save the appearance as a Style, where it could then be applied to other buttons or objects.
Before you give up on the Gradient Fill approach, be sure to try different styles—like Contour, for instance—and realize that you can scale the gradient and reposition it, to get the right effect.
Also, did you try the third solution: applying both Inner Shadow and Stroke as filter effects?
North America
Asia Pacific
