When I do a search and replace of a Column break and replace it with a Frame break, the paragraph and character formatting of the line on the next page clear any formatting applied to it.
I'm using CS6
Any ideas on how to do this without effecting the formatting?
Peter
You'd be better off controlling this in the paragraph style itself (Keep Options: Start Paragraph in Next Frame).
But if you're already far into the layout and don't want to change that, try doing a search and replace where Column Break is replaced with both a paragraph return and a Frame Break (if there is currently no return before the Column Break).
Thanks Richard, but that doesn't work either. When I add the Paragraph return and Frame Break it forces the Frame Break to the next card (see attached file) and after I search to replace the Paragraph Return and Frame Break to just a Frame Break the attached file shows what happens to the type.
Some how the Frame Break overrides the formatting of the line before it. Unfortunately I've already spent hours editing and formatting these cards (2,000 of them) and its more work to go back and do this in the original Word file.
Thanks for any help you may have.
Peter
Showing text threads might help understand it better.
Also, if this content originated as Word, there may be gremlins in the converted/imported/placed text. You might try, on a copy of the file, exporting as IDML and opening the IDML as an InDesign file.
HTH
Regards,
Peter
_______________________
Peter Gold
KnowHow ProServices
Thanks for the reply Peter, the text thread is from the left card to the right card, the Frame/Column Break in question is right before the Card number on the right hand card. That line is setup using auto numbering with a paragraph style and 2 character styles. The Word file is fairly clean as I clear overrides to it after I place it into InDesign then apply the same font, point size and leading to the entire file. Then do search and replaces to apply the other styles.
And Exporting to a IMDL file didn't change anything.
Peter
It's still a little vague to me... If the frame break is in the midst of a line of text, then:
* Is there a reason the end of the current card's content doesn't end with a paragraph return?
* Is there a reason the start of the next card's paragraph style doesn't have the start in new frame/colum/page property?
HTH
Regards,
Peter
Peter Gold
KnowHow ProServices
Yes, because the cards are done in a single format, for proofing and viewing and before going to the printer they are put into a file that's setup 100-up. And without the Frame Breaks the cards won't show up in all 100 boxes.
Unless there's a way to take the single cards and imposition them to 100-up in the proper orientation. 100-up Fronts and 100-up Backs.
Thanks!
I'm not sure why each frame/card's content won't be controlled properly with the start in new frame/column/page property, rather than needing a break character.
As to imposition issues, there are folks on this forum far more experienced than I am, in strategies for this.
HTH
Regards,
Peter
Peter Gold
KnowHow ProServices
Thanks!
North America
Asia Pacific
