I am trying to burn some HD BD. Using CS6
First tried exporting my 1920x1080i timeline as a BlueRay MPEG2 in Premiere.....when I imported into ENcore, it looks great. File is 1920x1080i, timeline is as well.
First burn, plays back as 720x480, 480i.
Then, tried same project, but selecting 1920x1080i in the "BD transcode settings" dropdown.
It took a lot longer, and same results, smaller file.
Then tried a different tact.....used Premiere's DLL function and burned another. This time the resulting disk wont even play, and it looks like there is no data on the disk.
Then tried to export the DLL version as a BD image file. Rebooted PC and then burned. Same result, no play at all.
Went back and makde an BD image file of my original mpeg2-BD file in Encore. Then tried to burn. Disk runs, but is again 480i.
Tried swapping monitors, no change. Only thing I havent tried yet is a different BD player (this one is a Sony). There are no settings that I have not tried.
Any ideas, anyone? Thanks in advance.
Please show people your Premiere Pro settings and your Encore settings http://forums.adobe.com/thread/592070?tstart=30
Well, turns out that the DVD player was acting goofy....Took the disks I made to another bluray player and they were fine as far as the playback resolution.
The sony bluray player I am using wasnt automatically changing to 1080i....I set it manually and all is OK.
Not sure why I had to change it manually though....the second bluray player I tried is the same exact model and had no issues....
Do the serial number "plates" on the two players show the same build date?
What MAY have happened is they were built on different dates... with slightly different firmware
You might check to see if there is a firmware update for your player
North America
Asia Pacific
