Hello, Im trying to impliment the JS code on the site below with regards to my spry tabbed pannels.
http://www.shinarp.com/SprySamples/tabbedpanels/tabbed_panel_sample3.h tm
I downloaded the file at http://www.shinarp.com/SprySamples/tabbedpanels/tabbed_panel_sample3_f iles/SpryTabbedPanelsExtensions.js and placed it in the root directory of my website.
To make this active, do i have to imbed the code from the first site into the HTML of the page with my tabbed panels? Here is the code:
<script language="JavaScript" type="text/javascript" src="../../widgets/tabbedpanels/SpryTabbedPanels.js"></script>
<script language="JavaScript" type="text/javascript" src="../../widgets/tabbedpanels/SpryTabbedPanelsExtensions.js"></scri pt>
<script language="JavaScript" type="text/javascript">
// Create the widget, and specify what interval you want
// to use when cycling through the panels.
var tp1 = new Spry.Widget.TabbedPanels("TabbedPanels1", { interval: 3000 });
// Start showing panels at regular intervals.
tp1.start();
</script>
Starting with a blank document, add the SpryTabbedPanels widget.
Ensuring that you have both SpryEffects.js and SpryTabbedPanelsExtensions.js in your SpryAssets folder, add a link to both of these files.
Then modify the selector to add the interval and a trigger to start the animation.
Your document should look like the following where the changes to the out-of-the-box widget have been highlighted.
<!doctype html>
<html>
<head>
<meta charset="utf-8">
<title>Untitled Document</title>
<link href="SpryAssets/SpryTabbedPanels.css" rel="stylesheet">
</head>
<body>
<div id="TabbedPanels1" class="TabbedPanels">
<ul class="TabbedPanelsTabGroup">
<li class="TabbedPanelsTab" tabindex="0">Tab 1</li>
<li class="TabbedPanelsTab" tabindex="0">Tab 2</li>
</ul>
<div class="TabbedPanelsContentGroup">
<div class="TabbedPanelsContent">Content 1</div>
<div class="TabbedPanelsContent">Content 2</div>
</div>
</div>
<script src="SpryAssets/SpryTabbedPanels.js"></script>
<script src="SpryAssets/SpryEffects.js"></script>
<script src="SpryAssets/SpryTabbedPanelsExtensions.js"></script>
<script>
var TabbedPanels1 = new Spry.Widget.TabbedPanels("TabbedPanels1", { interval: 3000 });
TabbedPanels1.start();
</script>
</body>
</html>
You need all the supporting spry .js and .css files in your own site folder or it won't work.
I think you can download them from Github as Adobe has given up on Spry.
http://blogs.adobe.com/dreamweaver/2012/08/update-on-adobe-spry-framew ork-availability.html
Nancy O.
jQuery Easy Tabs
http://os.alfajango.com/easytabs/#tabs1-html
Can be styled manually or with jQuery Theme Roller
http://jqueryui.com/themeroller/
Primer for Using jQuery Plug-ins
http://alt-web.blogspot.com/2012/11/primer-for-using-jquery-plug-ins.h tml
Nancy O.
North America
Asia Pacific
