QD-AU
Adobe Illustrator CS6 cannot open because of a problem
Jan 5, 2013 9:19 PM
Tags: #illustrator #error #adobe #crash #open #problem_opening_adobe
The problem details and System config:
Process:     Adobe Illustrator [57137]
Path:        /Applications/Adobe/*/Adobe Illustrator.app/Contents/MacOS/Adobe Illustrator
Identifier:  com.adobe.illustrator
Version:     682 (16.0.1)
Code Type:   X86-64 (Native)
Parent Process:  launchd [191]
Date/Time:   2013-01-06 16:13:06.798 +1100
OS Version:  Mac OS X 10.7.5 (11G63)
Report Version:  9
Interval Since Last Report:      264825 sec
Crashes Since Last Report:       3
Per-App Crashes Since Last Report:   2
Anonymous UUID:                  0C780427-F39A-4C90-AEBE-B1EE80F6CF77
Crashed Thread:  0
Exception Type:  EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Application Specific Information:
dyld: launch, loading dependent libraries
Dyld Error Message:
  Library not loaded: @executable_path/../Frameworks/AdobeCrashReporter.framework/Versions/ A/AdobeCrashReporter
  Referenced from: /Applications/Adobe/*/Adobe Illustrator.app/Contents/MacOS/Adobe Illustrator
  Reason: image not found
Binary Images:
   0x100000000 -    0x10186dfe7 +com.adobe.illustrator (682 - 16.0.1) <A69E28B6-CD5A-34FE-1F66-D7324B218021> /Applications/Adobe/*/Adobe Illustrator.app/Contents/MacOS/Adobe Illustrator
   0x101aaf000 -    0x1027f4ff7 +libicudata.40.0.dylib (40.0.0 - compatibility 40.0.0) <6211D655-ECF8-7378-CF68-3B07300D5A29> /Applications/Adobe/*/Adobe Illustrator.app/Contents/Frameworks/ICUData.framework/Versions/4.0/li bicudata.40.0.dylib
   0x102807000 -    0x102875fef +com.adobe.headlights.LogSessionFramework (??? - 2.1.2.1652) <25E6F475-1522-419C-2169-547FCF2FD97F> /Applications/Adobe/*/Adobe Illustrator.app/Contents/Frameworks/LogSession.framework/Versions/A/L ogSession
0x7fff62ae5000 - 0x7fff62b19baf  dyld (195.6 - ???) <0CD1B35B-A28F-32DA-B72E-452EAD609613> /usr/lib/dyld
0x7fff83932000 - 0x7fff83932fff  com.apple.CoreServices (53 - 53) <97E086D0-20B4-3BB4-BEE2-04EE5700D55B> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServ ices
0x7fff83933000 - 0x7fff83933fff  com.apple.ApplicationServices (41 - 41) <E23F1CED-C0FB-35A8-9657-484C5E6A32AE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/A pplicationServices
0x7fff84a4c000 - 0x7fff84a4cfff  com.apple.Carbon (153 - 153) <AF0F9910-E3C3-3922-AA92-A39000655E0F> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff852d0000 - 0x7fff855e9fff  com.apple.Foundation (6.7.2 - 833.25) <F6584E06-7C8F-3422-AF84-3AA58EC67935> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff8bff3000 - 0x7fff8bff3fff  com.apple.Cocoa (6.6 - ???) <9E3D4787-A2CE-38E0-BEF8-E5DA63B6E6A1> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff8c727000 - 0x7fff8d32dfff  com.apple.AppKit (6.7.5 - 1138.51) <44417D02-6123-3FC3-A119-CE51BB4C3006> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
Model: MacBookPro9,1, BootROM MBP91.00D3.B08, 4 processors, Intel Core i7, 2.3 GHz, 4 GB, SMC 2.1f170
Graphics: NVIDIA GeForce GT 650M, NVIDIA GeForce GT 650M, PCIe, 512 MB
Graphics: Intel HD Graphics 4000, Intel HD Graphics 4000, Built-In, 384 MB
Memory Module: BANK 0/DIMM0, 2 GB, DDR3, 1600 MHz, 0x80CE, 0x4D34373142353737334448302D434B302020
Memory Module: BANK 1/DIMM0, 2 GB, DDR3, 1600 MHz, 0x80CE, 0x4D34373142353737334448302D434B302020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xF5), Broadcom BCM43xx 1.0 (5.106.198.19.22)
Bluetooth: Version 4.0.8f17, 2 service, 11 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en1
Serial ATA Device: TOSHIBA MK5065GSXF, 500.11 GB
Serial ATA Device: HL-DT-ST DVDRW  GS31N
USB Device: hub_device, 0x8087  (Intel Corporation), 0x0024, 0x1d100000 / 2
USB Device: hub_device, 0x0424  (SMSC), 0x2513, 0x1d180000 / 3
USB Device: BRCM20702 Hub, 0x0a5c  (Broadcom Corp.), 0x4500, 0x1d181000 / 6
USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x821d, 0x1d181300 / 7
USB Device: Apple Internal Keyboard / Trackpad, apple_vendor_id, 0x0252, 0x1d183000 / 5
USB Device: IR Receiver, apple_vendor_id, 0x8242, 0x1d182000 / 4
USB Device: hub_device, 0x8087  (Intel Corporation), 0x0024, 0x1a100000 / 2
USB Device: FaceTime HD Camera (Built-in), apple_vendor_id, 0x8509, 0x1a110000 / 3
    Jan 6, 2013 1:10 AM   in reply to QD-AU
    Mmh, yeah, the Adobe crash reporter cannot be loaded, but why and how still remains in teh dark... Simply run the Creative Suite Cleaner Tool and reinstall.
    Mylenium
    Calculating status...
    Jan 8, 2013 3:46 PM   in reply to QD-AU
    The why is simple. This path is ridiculous:
    And when you re-install, stop moving your stuff around into subfolders, particularly subfolders named with a wildcard. That's a very System 7 way of thinking of software.
    Install it, then leave it the hell alone. When you don't, you deserve all the problems you experience as a result.
