Making FLV Interactive using Action Script 3
Jan 6, 2013 2:50 AM
Tags: #and #buttons #flvplayback #at #paused #cuepoint #certian #diplayed
Is it possible to pause FLVPlayback at certian point or cuepoint and display buttons. And hide buttons when not in that paused cuepoint.These buttons are used for navigation.
Thanks in Advance
God Bless You
    Jan 6, 2013 5:42 AM   in reply to BerpkeAhmed
    If you look up the FLVPlayback class in the help documentation you can find all of the properties, methods, and events that support it.  It does have a pause() method, so you should be able to trigger that with cuepoints or other criteria.
    If you are unfamiliar with how to find the help documentation for different objects, one easy way is to just type the class into the Actions panel, then place the cursor somewhere within what you just typed and right click it... from the menu that appears choose View Help.
    Jan 6, 2013 6:32 AM   in reply to BerpkeAhmed
    That code appears to be what you need to deal with cuepoint detection.  As far as doing anything with the player, it does not.  As I already indicated, you should look up the FLVPlayback class in the help files and see what is available for you to work with as a developer.  I believe you will find different elements of the interface that you can control in the Properties section.
    The help documentation and Google are two of the most valuable tools you have.  The sooner you get familiar with how to make the most of them, the better off you will be.
